QLD - Family Provision Claim
 To create a new Family Provision Claim matter, follow the steps below.
  2. Select State: QLD.
  3. Select Matter Type: Family Provision Claim.
  4. Select which party you are acting for (Applicant or Respondent/Personal Representative of the Estate):
  5. Enter the parties in the order in which they appear on the Originating Application.
    - See Adding Contacts for more information on adding contacts generally.
  6. For the Respondent / Personal Representative of the Estate, open 'Details' to add their capacity role, and relationship to the Deceased.
  7. For the Applicant, open 'Eligibility Details' to add their relationship to the Deceased, and eligibility under s 41(1) Succession Act 1981 (QLD).
  8. Select 'Estate Details' to add Will information, and administration details (if applicable):
  9. Select 'Case Details' to enter the Case Number, Division, List and Court:
  10. Enter the Court within the Case Details window. This will add the Court contact to your matter the same as any other contact card, allowing you to contact the Court and ensure automation works correctly. You do not need to add the Court as an additional contact outside of the Case Details window:
  11. Enter any Eligible Persons, and their relationship to the Deceased.
  12. Enter any Beneficiaries.
  13. To add Uncommon Contacts to your matter, open the Matter Settings and select the appropriate contact from the Parties & Data available in your matter.
    For Family Provision Claim (QLD), the available parties include Barrister, Mediator, Legal Agent, Expert, Accountant, Valuer, Process Server, Previous Solicitor and Additional Contact:
Change existing General matter to Family Provision Claim
Existing QLD General matters can be easily changed to Family Provision Claim as follows:
  1. Open your existing General matter (used for Family Provision Claim)
  2. Open Matter Type
  3. Select change...
  4. Select new Matter Type as Estate Disputes > Family Provision Claim
  5. Select OK:
  6. Select which Party you are acting for (Applicant or Respondent)
  7. Enter Reason For Change
  8. Select OK:
Your matter will now appear as 'Family Provision Claim', with the party roles and layouts that are available in the Family Provision matter:
Don't forget to! ...
Subscribe to the Estate Disputes Precedent Profile
If you can't see Estate Disputes precedents in your Precedent Library, you may need to subscribe to the Estate Disputes Precedent Profile in your Smokeball Settings:
We have some Family Provision Claim precedents and forms available in the Smokeball Precedent Library, including automated UCPR forms:
