Keeping track of the numerous documents, files, and attachments associated with a matter is a day-to-day challenge for any law firm. Smokeball solves this problem by providing an easy-to-navigate interface for your files at the bottom of each matter.
Navigate your files
Use the filters at the top of the Documents section to sort through them quickly:
Favourites show all files marked as favourites. To add a file to favourites, hover over it and select the star icon next to it.
- Documents show all document files, such as Word docs and PDFs.
- Messages shows all files shared via the Client Portal, Smokeball’s secure messaging system.
- Emails show any email correspondence around the matter.
- InfoTrack shows all files related to InfoTrack searches.
Create folders to organise files
Right-click any blank space on the documents section to create a new folder. You can also press Ctrl+Shift+N on your keyboard.
Search for a file
The search bar allows you to search for keywords that can be located in a file’s title and its contents.
Customise the files list
- Adjust the width of the grey column headers by clicking and dragging a border with your mouse cursor.
- Right-click on the grey table header to add or remove columns.
You can also toggle between a folder view and an all-files view by selecting the folder or bullet list icon.
- Use the eye icon to preview an individual file.
Double-click on a column header to sort files by alphabetical order, date, file size, and more.
- Note: Folders will always appear before individual files.
Use right-click to access file actions
One of the best practices in Smokeball is "right click is your best friend."
If you right-click any document in Smokeball, you will find a variety of options available for file management.
All right-click options are intuitive and can also be executed using hotkeys.
