- Create a Family Provision Claim matter
- Enter Parties
- Enter Estate Details
- Enter Case Details
- Enter the Court Details
- Add Uncommon Contacts
- Change existing General matter to Family Provision Claim
To create a new Family Provision Claim matter, follow the steps below.
- Select State: SA.
- Select Matter Type: Family Provision Claim.
- Select which party you are acting for (Applicant or Respondent of the Estate):
- Enter the parties
- See Adding Contacts for more information on adding contacts generally. - For the Respondent of the Estate, open 'Details' to add their capacity role, and relationship to the Deceased.
- For the Applicant, open 'Eligibility Details' to add their relationship to the Deceased, and eligibility under s 6 of the Inheritance (Family Provision) Act 1972 (SA)
Select 'Estate Details' to add Will information, and administration details (if applicable):
- Select 'Case Details' to enter the Case Number, Division, List and Court:
- Enter the Court within the Case Details window. This will add the Court contact to your matter the same as any other contact card, allowing you to contact the Court and ensure automation works correctly. You do not need to add the Court as an additional contact outside of the Case Details window:
- Enter any Eligible Persons, and their relationship to the Deceased.
- Enter any Beneficiaries.
- To add Uncommon Contacts to your matter, open the Matter Settings and select the appropriate contact from the Parties & Data available in your matter.
For Family Provision Claim (SA), the available parties include Barrister, Mediator, Legal Agent, Expert, Accountant, Valuer, Process Server, Previous Solicitor and Additional Contact:
Existing SA General matters can be easily changed to Family Provision Claim as follows:
- Open your existing General matter (used for Family Provision Claim)
- Open Matter Type
- Select change...
- Select new Matter Type as SA > Estate Disputes > Family Provision Claim
- Select OK:
- Select which Party you are acting for (Plaintiff or Defendant)
- Enter Reason For Change
- Select OK:
Your matter will now appear as 'Family Provision Claim', with the party roles and layouts that are available in the Family Provision matter:
