Created a lead that hasn't been converted to a matter? Learn how you can close a lead in Smokeball.
Close a lead in the Smokeball Desktop App
- Open the lead, then double-click on Info under Lead Details.
- In the Lead tab, choose Closed from the Status drop-down menu.
- Optional: Select a reason for closing the lead from the Lead Closed Reason drop-down menu.
- Select OK.
It is also possible to close a lead by selecting the Open button in the lead header and choosing Closed from the drop-down menu.
Close a lead in the Smokeball Web App
- Open the lead, then select Edit Lead on the right-hand side of the screen.
- Under the Lead Details section, change the Lead Status to Closed using the drop-down menu.
- Choose a Lead Closed Reason from the drop-down menu.
- Select Save Lead at the bottom of the screen.
Delete a lead in the Smokeball Desktop App
If a lead was created by accident, you can delete the lead by selecting File from the top-left corner of the lead and then selecting Delete.
When a lead is deleted, it is not permanently deleted from Smokeball. View deleted leads by selecting the filter on the top-right corner of the Matter View.
Delete a lead in the Smokeball Web App
To delete a lead in the Smokeball Web App:
- Select Edit Lead from the right-hand side of the lead.
- Select Delete Lead on the bottom-right corner of the screen.
- Confirm deletion by selecting Delete.
Deleted leads are not permanently deleted from Smokeball. To view a list of deleted leads, navigate to the Leads tab and toggle on Deleted under the Lead Status section on the left menu.
