Add a workflow to a lead
Use workflows to automate tasks related to managing leads.
Create a lead workflow
  1. Select the gear icon on the top-right corner of Smokeball.
  2. Select Workflows from the left menu, then select Add New.
  3. Name the workflow, then select New Task to start building the workflow.
    • Complete the Name, Due, and Assign to fields.
    • Add a Leads category to each task to better track all your leads’ tasks. Type the category in the field and press enter to apply it to the task.
  4. To ensure the workflow shows up for leads, apply it to the correct Lead Types by selecting change... and ticking all the Lead Types that it applies to.
    • Note: Make sure you are ticking lead types that display under the Lead Types folder, not the Matter Types folder, or else workflows will not apply to the leads.
  5. Tick always apply this Workflow to new Matters.
  6. Select Save & Close.
Apply a workflow to an existing lead
  1. Open the lead, then select the Tasks tab.
  2. Select Apply Workflow.
  4. Select Next, then Done.
3 out of 3 found this helpful
