Connect InfoTrack to Smokeball
Learn how to integrate your InfoTrack account with Smokeball for easy access to their services directly from Smokeball.
Don’t have an InfoTrack account? Get started from the InfoTrack website.
Connect InfoTrack via Smokeball Settings
  1. Select the gear icon on the top-right corner of Smokeball to access Smokeball Settings.
  2. Select Integrations from the left panel, then select InfoTrack.
  3. Tick Automatically save completed orders to your matter and/or Automatically create disbursement for each order (optional, but recommended).
  4. Select Authorise.
  5. Follow the prompts to enter your InfoTrack username and password, then select Authorise.
  6. Select Save.
Now you can access InfoTrack features in Smokeball. Learn more about using InfoTrack within a matter.
0 out of 1 found this helpful
