Drafting correspondence with Archie
In this article, learn how to use Archie to draft correspondence.
First time hearing about Archie? Learn more in Getting Started with Archie, the Smokeball AI Assistant.
Currently, Archie can compose emails, letters, clauses, and legal documents seamlessly integrated with Outlook and Word. We are working on expanding Archie's drafting capabilities in the future.
Using Archie for drafting
Archie can streamline client communications by drafting emails, keeping clients updated, and composing formal letters effortlessly. Just give clear instructions, and Archie will handle the rest.
If you're not happy with the response, prompt Archie again for a different tone or format. You can always edit Archie's response, saving you time starting from scratch.
  1. Open a matter in the Smokeball desktop app.
  2. Select the Archie tab.
  3. Select the Quill icon and choose the type of document to draft.
  4. If drafting an email or letter, select the party in the drop-down list.
  5. If drafting a clause, document or memo, ensure the respective button is selected.
  6. Enter your prompt or instructions into the text box, then select the arrow in the bottom right corner.
  7. Archie will generate a draft, denoted in a light blue box.
  8. Scroll to the bottom of the response for further actions:
    • Change Tone
    • Change Length
    • Improve Writing
  9. Under the draft, you can also:
    • Give us feedback about the response with a thumbs-up or thumbs-down. This will help refine the quality of Archie's responses in real-time. Note: This option only appears for Archie conversations that you initiate.
    • Copy the response to your clipboard
    • Save the response as a memo to your matter
    • Open the response in Microsoft Word (handy for drafting documents)
    • Open the response in Microsoft Outlook (handy for drafting emails)
    • Send the response as a Client Portal message
    • Regenerate response
  10. When you are happy with the email or letter draft, select Create Email From Draft or Create Letter from Draft.
  11. Proceed to send the letter or email to the recipient from Word or Outlook. Any emails and letters sent will be saved to the matter.
Expectations and limitations with Archie for drafting
Archie can:
  • Draft correspondence such as emails, letters, and messages
  • Change the tone of voice for correspondence
  • Draft legal documents such as clauses and contracts
Archie cannot:
  • Draft text unrelated to the matter, such as a blog announcing your firm’s expansion to another city
  • Translate or write in another language
  • Automatically write correspondence in your firm’s tone of voice
Smokeball AI disclaimer
Like many AI software programs, Archie is a powerful tool that saves time and effort. However, while an answer may sound correct and read well, it may not be correct.
It is incredibly important to Trust but verify. Always read responses from Archie carefully to ensure that they are accurate.
We recommend verifying Archie's responses by checking the links to supporting documents provided at the bottom of the responses, if applicable.
5 out of 5 found this helpful
