What are Archie Suggestions?
Archie Suggestions are recommended next steps based on the activity and content in your matter.
Archie reviews items such as documents, emails, tasks, and deadlines, then presents relevant actions you can take. These appear as clickable tiles that you can review and choose to run.
Where to find Archie Suggestions
You can access suggestions in the following areas:
Matter Widget
Open a matter
Locate the Archie panel on the right-hand sidebar
It is recommend to Right Click on Archie at the top of the right-hand sidebar and choose Set as Default
Review available suggestion tiles
Archie Chat
Click the Archie tab at the top of the matter
Suggestions will appear below the chat interface
Click on the Refresh icon to generate new suggestions. Suggestions also automatically refresh every 24 hours.
Microsoft Word
Open a document connected to a matter
Archie will display suggestions based on the document content
How to use a suggestion
Follow these steps to run a suggestion:
Review the Suggestion Tile
Review the recommended action, reasoning, and review any relevant files or content included.
Run the suggestion
Click the tile to generate the draft, task, event, or output
Review And Confirm
Review the generated result
Choose to confirm and save/send/create, or dismiss if not needed
When the suggestion includes an Archie app, clicking on the suggestion tile takes you directly to the app experience.
For all other suggestions, clicking the suggestion tile takes you to a new chat with Archie where the suggestion is automatically sent as a prompt.
Types of suggestions you may see
Archie Suggestions generally fall into the following categories:
Create a task
Generates a task with suggested details
Edit as needed before saving
Create a calendar event
Creates a calendar entry based on matter activity or deadlines
Create a memo
Drafts a memo using relevant matter information
Draft an email
Prepares an email based on matter context
Prompt suggestions
Provides a pre-written prompt you can run without typing
App recommendations
Suggests an Archie App relevant to the matter content
Understanding suggestion tiles
Each suggestion tile includes:
Action
The task Archie recommends
Reason
A brief explanation of why the suggestion is being made
Files
The documents or emails that will be used to complete the action
Important notes
Suggestions are not executed automatically
You must review and confirm before anything is created, saved, or sent
You can ignore or dismiss any suggestion that is not relevant
