Move files out of a base template suite
By default, you cannot move files out of the base template suites in the TemplateLab Library to another folder. Base template suites are denoted by a white rectangle in the upper-right corner of their folder icons.
If you need to move a file from a base template suite, use this workaround:
  1. Right-click, hold, and drag the form/folder you wish to move from the base suite to the new destination folder.
  2. Select Copy Here.
  3. Optional: Delete the original copy of the file in the base template suite.
The first two steps are illustrated in the animation below:
Alternatively, you can:
  2. Select Create shortcut here.
You can copy a template you create from one state to another by selecting Show all form suites on the TemplateLab Library window and then moving the template to the desired state with the folder directory in the left pane.
You must right-click on the template you wish to move and hold the right-click button down before dragging it to the destination folder. Release the right-click button and then select Copy Here.
If the template was originally in the wrong state, you can right-click on the template in the state you copied it from and select Delete.
0 out of 2 found this helpful
