Learn how to use the Knowledge Sources section in Archie to store resources that provide extra context for answering prompts.
What are Knowledge Sources?
Knowledge Sources hold your firm's reference material. These are documents that apply across many matters, not just one. Archie can search through knowledge sources when answering questions and composing drafts on a matter.
Some good things to add as Knowledge Sources include:
- Legislation
- Court rules
- Regulator guidance
- Authorities your firm relies on
- Internal process notes and checklists
- Precedent commentary
Don't add anything that belongs to a single matter - Archie already reads those from the matter itself.
How Archie uses your Knowledge Sources
Archie doesn't read your documents from start to finish. It searches them for the passages most relevant to the question, then reasons over those passages alongside the matter.
- When you upload a Knowledge Source: Each document is broken into short, searchable passages. PDF and Word files keep their page numbers, headings and tables, so Archie can cite the page.
- When the source is switched on: Archie writes a short summary of what the source covers.
- When someone asks a question: Archie compares the question with the summaries of the sources available on that matter and decides whether any are worth searching. If the answer is in the matter itself, Archie won't search a Knowledge Source.
- When Archie searches a Knowledge Source: Archie reads the most relevant passages, writes its answer and cites each source it relied on.
Knowledge Sources gives Archie material to reason with. It is great for finding, interpreting and applying what your firm knows. However, it isn't a reliable way to get a document back exactly as you stored it.
Adding a Knowledge Source
Knowledge sources are available across all matters and can be added from an individual matter.
- Open a matter in the Smokeball Desktop App or Web App.
Select the Archie tab and navigate to the Knowledge Sources tab on the left panel.
Select Add Knowledge Source. Enter a name and brief description of the knowledge source, then select relevant Matter Types. Removing all Matter Types from the box means that the knowledge source will be available for all Matter Types.
- Select Create Knowledge Source.
A new window will open for you to configure the knowledge source. Select Browse to upload one or more documents (PDF, DOCX, TXT or MD) from your PC.
Once you upload documents, text will be extracted from them. This may take a few minutes and the Status column will indicate progress. You can leave this screen at any time as the process runs in the background.
Once it has finished processing, the toggle on the top-right side of the screen will become available. Select whether to activate the knowledge source for yourself or all staff members using the drop-down menu, then click on the toggle to make it Active.
Once a knowledge source has been toggled to Active, Archie will take it into account when generating a response to a prompt.
Using Knowledge Sources in an Archie conversation
By default, Archie selects relevant knowledge sources when you ask a question. You can change this by clicking the Knowledge Sources icon in the chat box to choose specific sources or disable them entirely.
When Archie is thinking of a response, the knowledge sources are listed to show you that they are being utilized.
Knowledge Sources for Research
Links to knowledge sources are cited in Archie responses. Click on the reference to open a preview of the knowledge source on the right-hand side of the screen.
