Create Calendar Events
Smokeball Desktop Web App
Smokeball's calendar syncs directly with Outlook.
Every event created in Outlook will appear in Smokeball, and every event entered in Smokeball will appear in Outlook.
Smokeball also will add calendar events to Activity. The best practice is to create calendar events from a specific matter.
If you are using Outlook as your primary calendar, jump ahead to Use Outlook As Your Primary Calendar for suggested best practices.
Create a calendar event
To create a calendar event in Smokeball:
  1. Select the Event button from your matter’s action bar.
  2. Complete all of the fields in the New Event window. We recommend starting at the top and working your way down to enter a subject, location, and time. You can also add attendees and comments in this window.
    • Note: Each staff member added to the event will be tracked by Smokeball as having attended. Smokeball will bill for each staff individual's time at the event if the Billable checkbox is selected. You may wish to de-select the Billable checkbox if you do not wish to bill for everyone's time at once and later add that event to the invoice as a separate time entry. Alternatively, you can assign the event as a task to those staff members whose time is not meant to be billed, but keep in mind a task will not sync to their calendar.
Optional: If you have enabled Smokeball’s Zoom integration, you can set up a Zoom meeting by selecting the Use Zoom checkbox.
Communicate and calendars
You can also invite clients to events through Communicate by using the Parties dropdown menu. Contacts selected in the Parties menu will receive an automatic reminder one day before the event in Communicate. Learn more about using Communicate for calendar events.
Track your calendar events
  • Each matter has an Events tab that includes previous and upcoming events in relation to a specific matter
  • To see your calendar events for all matters, go to the Calendar view on the home screen. You can filter calendar events by day, work week, week, and month using the buttons in the upper right corner of the calendar. You can also choose to view calendar events as a timeline.
  • You can create calendar events from the home screen.
    • Make sure you assign the event to the appropriate matter (if applicable).
Using Outlook as your Primary Calendar
Your firm may use Outlook as their primary calendar based on familiarity or features Outlook provides that Smokeball does not. If your firm prefers Outlook, you should:
  • Review How Should I Calendar in Smokeball? or talk to your Account Manager about the best practice for your firm.
  • Tag the appropriate matter for any calendar event when creating the event in Outlook.
  • Keep in mind that all events created in Outlook will appear in Smokeball's Calendar.
3 out of 6 found this helpful
