In Smokeball Boost, you can use the Dashboard view to get a high-level view of your tasks and activity.
The dashboard is populated by a number of widgets - add more widgets to the dashboard by accessing the dashboard library.
Add or edit a dashboard
- Select the Pencil icon on the right-hand side of the screen.
- Click on Add Dashboard. On the left-hand side of the screen, a New Dashboard will appear.
- Select the arrow icon to rename or delete the dashboard.
Change a dashboard layout
- Select the three vertical dots on the top-right corner of a widget to view its settings or delete it.
- Click and drag the arrows on the bottom-right corner of a widget to resize it on your dashboard, allowing you to fit more widgets on it.
- Click and drag the heading of the widget to rearrange it to any free space on the dashboard.
Note: Only you can see changes made to your dashboard. Changes you make on the dashboard customisation screen are not visible to other users in your firm.
Add widgets to a dashboard
Use the Widget Library to find and choose widgets that best suit your needs. To get started, select Add Widget.
The Smokeball Team regularly releases new widgets in the Widget Library. Learn more about Smokeball Boost dashboard widgets.
