View all Settlement Dates and Conveyancing Critical Dates
Smokeball offers widgets for tracking Settlement and Conveyancing Critical Dates on your Dashboard, for all matters or specifically your matters.
To add the widget to your dashboard:
  1. From the Smokeball desktop app, select the Dashboard from the left menu.
  2. Select Customise located on the top-right corner of the dashboard.
  3. Ensure you have space created on your dashboard. You can also add a new dashboard specifically for this.
    • You can add multiples of the same widget on a single dashboard. See the Tips section at the bottom of this article for dashboard design ideas.
  4. Select Add widget on the top-right corner of the dashboard, then choose Critical Dates from the left menu.
  5. Click on the widget you wish to add. You can configure its settings to customise the information shown.
  6. Select Add.
  7. (Optional) Resize the widget by dragging the bottom-right corner to your preferred size.
  8. Select Save to save the dashboard layout.
Tips for organising your conveyancing widgets
Here are some example dashboards we have created that can serve as inspiration for displaying Settlement Dates and Conveyancing Critical Dates.
Want to separate your lists so you have one for each critical date? Create a “Critical Dates” Dashboard featuring one widget per date type.
Want better visibility over your staff members' upcoming critical dates? Add a widget for each staff member.
5 out of 5 found this helpful
