How to create a custom Intake Form
Learn how to create your own Intake Forms with your desired fields.
Your firm will have access to custom Intake Forms through the Intake add-on. However, your access may depend on your Smokeball plan and which add-ons you have signed up for. If you have any questions regarding this, please contact your Client Success Manager.
Accessing the Intake Forms builder
To get started, navigate to the Intake Forms window.
Creating the form
  1. Select Create Form and choose either Lead or Matter as a Form type.
  2. Enter the Form name and select the relevant States and Matter types you'd like to use this form for.
  3. Choose the Form building option that you would like to proceed with:
    • Generate using Smokeball AI: This creates an AI-generated form based on what you have entered as the form name, state and matter type selection.
    • Upload and convert an existing form: If you have an existing Word or PDF form that you would like to use as an Intake Form, choose this option. Smokeball AI will analyse the form and recreate it to the best of its ability.
    • Build custom form: Create a blank form to build from scratch.
  4. Click the Create Form button. This will open the Form Builder.
Note: Smokeball is able to help you create a custom intake form using our AI tool and convert an existing form your firm has created into a Smokeball intake form.
Changing the form type
If you wish to change a form from Lead Intake to Matter Intake or vice versa, click on the Matter type text under the form's name. The Update Form window will open for you to make changes to the form type.
Important notes:
  • Changing the form type will reset the Matter Types drop-down menu. You must reselect them before updating the form.
  • Mapped field components that were present in the original form will be converted into Text components.
Building and editing the form
A custom Intake Form is made up of sections that contain components.
Sections
The left panel of the form builder contains all the form sections. Each section represents a page for your form. For example, the first section could be where prospective clients enter their basic information, and the second section could be where they start providing details.
  • Select the Text icon near the Section Title to add a brief description of the section.
  • Select the Edit button to add, rename, delete or rearrange sections in the form.
Components
The right panel of the form builder contains components, which are the building blocks for the form.
View a list of all available components you can add to your Intake Form.
  • To add a component, drag and drop it over to the middle of the form builder.
  • Rename a component by clicking on its name, entering the new name and pressing the Enter key on your keyboard.
    You can also highlight any part of the text to make it bold, italic, underlined, or to insert a link.
    There are also options to change indentation and make the field names numbered or have bullet points against them.
  • Rearrange components on the form by dragging the dots on the left side of the component.
  • Select the field settings icon in the top-right corner of the component to access further actions, such as:
    • adding description text
    • marking the component as mandatory
    • deleting the component.
      Field settings vary depending on the component.
  • To convert a component to a different type, click on the component type (as shown below).
    This is useful if you have changed the type of Intake Form (e.g. converted it from Matter to Lead intake or vice versa), since switching form types will convert mapped components into text components.
  • To move an existing component to a different section, drag and drop it into the desired section.
Adding conditions to your form
Conditions create a logical flow in your form based on the responses given.
For example, if a respondent selects an option in a Choice component or enters information in a text field, a different component will appear based on what they selected.
You can set up conditions in the following component types:
  • Text (includes Text options in mapped fields)
  • Choice (includes Choice options in mapped fields)
  • Multi-select
  • Number
To access conditions:
  1. Select the double arrow icon on the bottom-right corner of the component where you wish to start the flow:
  2. Select Add condition. An "If" and "Then" line will appear on the screen.
  3. The "If" line triggers what happens in the "Then" line. Select the appropriate options under the Choice and Answer drop-down menus.
  4. Select the appropriate Component.
    • Question: Send the respondent to a single component in the remaining form.
    • Section: Send the respondent to a different section in the remaining form.
    • Group: Send the respondent to a Grouped Field in the remaining form.
  5. Select Add condition to add multiple conditions to the component.
  6. Once you are done, select Save conditions.
Notes:
  • When selecting a component in the Then line, only subsequent components to the form will appear. This prevents you from creating circular logic flows.
  • Components with condition/s attached to them are denoted with a red notification on the arrow icon.
  • You can chain conditions together as far as you like. The top of the conditions window displays the condition set before and after a component, so you can check the flow at a glance.
Previewing your form
Editing the Confirmation Message
Select Settings to preview and make changes to the confirmation message that appears after the respondent completes the form.
You can also choose from a set list of automated fields by selecting the A icon in the text editor.
Previewing the form end-to-end
Select the Preview form button at the top of the form builder to view how the form appears to respondents.
To easily progress through the form without filling in mandatory fields, uncheck Field validation.
Publishing your form
Save all changes to your form by selecting Publish on the bottom-right corner of the editor.
You can add a change note, which tells other users what changed.
Select Publish to save the form.
Once you are ready to share the form with clients, toggle on Active next to the Settings button.
You can also toggle it on from the list of Intake Forms.
Editing your form
You can return to the editor at any time by accessing the list of Intake Forms and clicking on the form you want to edit.
Note that you cannot edit forms that list "Smokeball" as the Created By user. However, you can duplicate the form and edit the duplicate if you wish.
Duplicating a form
You can duplicate a form by clicking the three dots icon next to a form and selecting Duplicate.
This will help you to make minor modifications to the form without having to recreate it.
Organising your forms
You can filter matter and lead Intake Forms by state, matter type, and creator using the filter icon.
Deleting and restoring a form
To delete an Intake Form, select the three dots icon next to it and click Delete.
To restore a deleted Intake Form, filter the list of forms to only show Deleted forms. Then, select the Restore icon next to the form.
Embedding a Lead Intake Form on your website
To enable prospective clients to complete your custom form, you can embed it on your website.
Do you have additional questions about setting up your custom Intake Form? Our Frequently Asked Questions article may have the answer.
14 out of 18 found this helpful
