When sending Intake Forms to clients, you can customise the messaging when they interact with the form.
Currently, you can customise the messages that go out when:
- A client or prospect receives an email or Client Portal message to fill in a lead intake follow-up form or matter Intake Form (New Intake Message (Lead or Matter))
- Your firm sends a client or prospect a reminder message to complete a form (Reminder Message)
- A client submits a form (Confirmation Message)
Customise client messages across all forms
To customise client messages:
- Select the Settings (gear) icon to access Smokeball Settings.
- Select Intake Forms from the left menu.
- Select the Client Messages tab.
- Click on the message you wish to edit to open the text input box.
Customise client messages on specific forms
If you wish to make a one-off edit on a specific form, select Settings on the top-right corner of the Intake Form Builder, then select Message Templates.
Note: Settings in this Message Templates section will override the firm-wide configuration in Smokeball Settings.
Customise text in the client message text box
The toolbar in the text box allows you to change text styles (e.g. bold or italicised).
You can also add links by selecting the link icon and entering the URL and the text it should display.
Select the black square icon (beside the link icon) to add common automated fields to the message. When the client or prospect views the message, these fields will be automatically populated with data from the matter or lead.
The data for the Firm Name and Firm Phone fields are gathered from your Firm Details in Smokeball Settings.
What does my message look like from the client or prospect perspective?
Refer to these sample messages to see what clients and prospects receive:
Client Portal message view
Email view
Reminder Message
Email view
This message will appear after the client or prospect submits a form.
