Generate a custom Intake Form using Smokeball AI
Learn how to create a Lead or Matter Intake Form from scratch using Smokeball AI.
Generating a custom Intake Form is available as part of the Intake addon and included in Smokeball Prosper+. The Archie addon is not required for this feature. To learn more about addons, please reach out to your Customer Success Manager.
To get started:
1. Navigate to Intake Forms in the Smokeball Desktop App or Web App.
2. Select the Create form button.
3. Choose Matter or Lead.
4. Enter a name for the form, the relevant state/s, and the appropriate matter type/s.
5. Select Generate using Smokeball AI from the Form building options and then click the Create form button.
Smokeball AI will generate a template Intake Form based on the state/s and matter type/s selected.
Convert an existing form into a Smokeball Intake Form
Alternatively, you can convert an existing paper form into a Smokeball Intake Form using AI.
4. Enter a name for the form, the relevant State/s, and the appropriate Matter type/s.
5. Select Upload and convert an existing form from the Form building options section.
6. A section will appear that allows you to upload a copy of the form.
Drag and drop the .PDF, .JPEG or .PNG copy of the Intake Form into the boxed section or select Browse to select it from your computer's hard drive.
7. Once the file is uploaded, click the Create form button.
10 out of 12 found this helpful
