Collect matter information using Matter Intake
Learn how to use Intake to collect data directly from your clients and have this automatically flow into your matter.
Creating a Matter Intake form from a lead that came through via your Lead Intake Form? Select Convert to Matter on the lead to get started.
Configure Matter Intake settings
The Intake add-on in Smokeball involves sending out forms tailored to the matter's area of law.
To ensure your Intake Forms have been set up for the relevant states and areas of law that your firm practises in:
  1. Navigate to Smokeball Settings on the top-right corner of Smokeball and select Intake Forms.
  2. Select the Practice Areas tab and check that your states and areas of law are listed there.
  3. Select Edit to add or remove states or areas of law.
  4. Select Save.
Create a new Matter Intake Form
To get started with sending an Intake Form to your client:
  1. Open the matter and select the Intake tab.
  2. Select Share Form.
  3. Select a form from the Form drop-down menu. Then, verify the details of the client's Contact card and Email.
    The Form Preview will automatically populate fields with information from the matter details.
  4. Choose whether you wish to send this form via the Client Portal or email. Edit the message if needed.
    • Select the Custom Field icon to insert specific fields from your matter into the message.
    • You can customise this message for all matters in Smokeball Settings > Intake > Client Messages.
  5. Select Share to share as a Client Portal message, or Open Email if sending the form as an email.
Create a custom form
You can easily create a Matter Intake form with the fields of your choice. Refer to the Create a custom Intake Form article for more information on how to set this up.
Monitor Matter Intake progress
To view all shared Intake Forms across all matters, along with their progress, click on Intake from the left menu on either the Smokeball Desktop App or Web App.
You can also add the Intake Widget to your Dashboard, as a total number or list.
Matter Intake Actions
On the Intake tab, you will see a list of all forms involving the client.
Clicking on the three dots icon next to the form will open up a list of actions you can take on the form:
  • View - Access the form from the client's perspective.
  • Send Reminder -  Send a Client Portal or email message to the client as a reminder to complete the form.
  • Copy Link - copy the URL of the form to your clipboard.
  • Show QR Code - view and/or copy the QR code of the form to your clipboard.
  • Edit Responses - make changes to form responses.
  • Close Form - Close access to the form, if you have collected data from the client elsewhere.
  • Delete Form - Delete the form. This can only be done if the Modified field shows "Not opened".
Save form responses to the matter
To view the responses that the client has entered so far, click on the form name or select View from the three dots icon.
To copy these responses to the matter, select Save Responses (Save icon).
Notes:
  • When you save Responses, it will overwrite any existing fields in the matter.
  • The Save Responses button will not appear for any FamilyProperty forms sent to the client (e.g. Questionnaire).
2 out of 4 found this helpful
