Intake Forms - Frequently Asked Questions
Below are some frequently asked questions about the Intake add-on in Smokeball.
Is our firm able to create its own Intake Forms?
If you are the Firm Owner, you can create a custom lead or matter Intake Form for your firm. To get started, follow the steps in the Create a custom Intake Form article.
How do I view the Intake Form that was shared with my client?
To view an Intake Form, open the Intake Forms tab in the matter or lead file. Then, select the three dots on the right-hand side of the Intake Form and click on View.
How can I set up staff members to receive notifications when Intake Forms are completed?
Note: The following setting only applies for Smokeball Grow and Prosper+, as notifications are delivered via the Notification Centre in the Smokeball Desktop App. With Smokeball Boost, the Form Sharer is the sole user who will receive completed Intake Form notifications.
To define who should receive intake form completion notifications:
  1. Navigate to Settings and select Intake Forms from the left-hand menu.
  2. Select the General tab.
  3. Tick the roles that should receive notifications upon Intake Form completion. If you tick Staff, you can nominate the staff member/s that receive notifications.
How do I display my firm's logo on the Intake Form?
Ensure you have uploaded your firm's logo on Firm Details in Smokeball Settings. This is where the form will grab your logo information from.
Why can't I choose my state or matter type / Why can't I see any forms?
If you are experiencing issues creating or selecting a form, check that you have set up your firm's practising states and areas of law correctly.
  2. Select the General tab and check that your States and Practice Areas are listed there.
  3. Click the dropdown arrows to add or remove States or Practice Areas.
  4. Click the Save button to save changes.
Can I revert changes made to an Intake Form?
You can restore previous versions of an Intake Form by selecting Settings on the top-right corner of the form editor, then selecting Version History.
Versions are saved once a day at 11:59 pm (Sydney time). A version is only saved if changes were made in the past 24 hours.
Reverting to an earlier version doesn’t delete newer ones, but any changes made in the 24 hours before the save time will be lost.
Learn more about Version History in Intake Forms.
Why can't I edit an Intake Form?
If the option to edit a form does not appear when you select the three-dot icon next to it, it may be because it was Created by Smokeball.
You can edit the form after selecting Duplicate Form and then clicking on the duplicate.
Why can't I delete a matter Intake Form?
The ability to delete a form is reserved for the situation where you have shared a form by mistake, e.g. to the wrong client.
To delete a form, the client must not have opened it. You can confirm this by checking the Modified column for the form, which should show Not opened.
If the client has opened the form, you will have to Close the form instead.
How do I delete or close Intake Forms in bulk?
You can delete multiple Pending Intake Forms from the general Intake View located on the left menu of the Smokeball Desktop or Web App. Tick the forms you wish to delete or close, then select Bulk Actions.
How do I configure multiple parties to fill out the same Intake Form?
There are two ways to configure your Intake Form to collect data from multiple parties:
  • When sharing a form where multiple parties can view each other's contact details (e.g. for conveyancing intake), create a set of grouped repeatable fields to collect their information. Additional parties can click +Add on the form to provide their details.
  • When sharing a form where multiple parties must not view each other's contact details (e.g. for family intake), avoid using grouped repeatable fields. Instead, include a single set of contact detail fields on the form. When Party 1 completes the form, their details will populate the Party 1 section in Matter Details. Similarly, when Party 2 completes the form, their details will appear in the Party 2 section of the matter.
I embedded a form on my website. If I edit the form in Smokeball, do I need to generate a new code?
Changes made to the form in Smokeball will automatically be pushed through to your website, so you don't have to generate a new code from Intake Form Settings.
Will the system check for duplicate names submitted via my web form?
Before creating a contact after form submission, the system searches for any existing contacts that match the following criteria:
  • For Individual Clients, we check if there is already a contact with the same FirstName, LastName, and email address, and use that contact instead of creating a new one.
  • For Company Clients, we check if there is an existing contact with the same CompanyName and email address. If a match is found, we use that contact instead of creating a new one.
What anti-bot measures are there in the Intake Form process?
We have implemented the following measures to combat bot and spam responses:
  • reCAPTCHA runs in the background of the Intake Forms website.
  • Form submissions from the same device require a wait time between each submission.
  • Automated verification measures are run once a lead form is submitted, which assesses if the form is a genuine enquiry or spam. You can review flagged responses from the Intake Forms Dashboard, accessible from the left panel of the main Smokeball window.
Can my firm use Intake Forms if we are also using FamilyProperty?
Smokeball Intake Forms do not impact your FamilyProperty setup.
You can choose Family Law in the Practice Areas section of Intake Settings and use Intake Forms alongside FamilyProperty's specialised and detailed forms.
My client's email system is marking Intake Form-related emails as junk. How do I fix this?
When you send an Intake Form email through Smokeball, your email address will be listed as the sender of that email. Ensure your client has whitelisted any emails coming from your email address.
Also, ensure that the contents of your email (subject and body text) do not contain spam trigger words such as 'free', 'discount', or 'guaranteed', as this can trigger your client's email provider to mark the email as spam.
Can I hide forms created by Smokeball?
Yes, you can hide forms created by the Smokeball Team from appearing in the list of Intake Forms for your firm. To do this, navigate to Smokeball Settings or Firm Settings and select Intake Forms. Then, select the General tab and toggle off the option Show Smokeball Forms.
9 out of 20 found this helpful
