Microsoft Office Add-in troubleshooting guide
Use this troubleshooting guide to resolve issues with the Smokeball add-in for any Microsoft Office applications.
The guide outlines a series of checks and steps you can take to re-enable the integration.
Important Note
This guide is intended for Windows administrator users. Please forward it to your IT team if applicable.
Check Smokeball Add-in Status
If the Smokeball Add-in is non-interactive, unresponsive or missing:
  1. Open any Office application (e.g. Word, Outlook).
  2. Select File from the top-left corner of the application, then select Options in the bottom-left corner.
  3. Select Add-ins from the menu on the left and choose COM Add-ins from the drop-down menu at the bottom of the window.
  4. Click the Go button.
  5. Untick Smokeball Toolbar and click the OK button.
  6. Return to the Options > Add-ins > COM Add-ins window and re-tick Smokeball Toolbar. Then, click the OK button.
Check Office Updates
  2. Select File from the top-left corner of the application, then select Account from the bottom-left corner.
  3. On the right-hand side of the screen, click on Update Options, then select Update Now.
Compare Smokeball and Office installation dates
  1. Open the Start menu and type in "Apps & features" to access the Windows Apps & features list.
  2. Use the search bar to find "Smokeball". Take a screenshot of the result.
  3. Use the search bar to find "365". Take a screenshot of the result.
  4. If the Smokeball installation date is later than the date listed for Office 365, continue the troubleshooting steps in this guide.
  5. If the Office 365 installation date is after Smokeball, uninstall and reinstall Smokeball.
Check Office Safe Mode
If the issue relates to Smokeball conflicting with the usage of standard Office application features, confirm if this is replicable in Office's safe mode state.
In safe mode, the Smokeball add-in does not run, along with other third-party features. Running safe mode can confirm if the Smokeball add-in is the issue.
To open Office in safe mode:
  1. Open Windows Run (Windows Key + R).
  2. Type in the command [appName].exe /safe (where appName = the official name of the Office application, such as Winword, Outlook, Excel). Safe mode will now boot.
  3. Document all results while attempting to replicate the issue in safe mode.
Repair and reinstall Office
If an issue with Office persists after disabling Smokeball add-in or uninstalling Smokeball, perform an Office repair.
Learn more about repairing Office from the Microsoft website.
If repairing Office does not resolve the issue, consider reinstalling Office as a last resort. This should be completed by IT or the administrator.
If all of the above steps have been attempted and the issue with the add-in persists, please contact our Support team for further assistance. When sending in a support request, please include any screenshots, screen recordings, or other documented results you have based on the steps outlined above.
0 out of 6 found this helpful
