Smokeball Bill and Boost Releases May 2026
Plan_BillBoost.svg
4 May 2026
Archie for Boost has been updated with the following new features:
New Agentic Model
Archie's engine has been updated to better assist with complex queries and workflows. It will now work through your matter more deliberately, by:
  • Checking if there's enough context in your matter before responding
  • Giving clear signals when something isn’t fully supported
  • Having stronger continuity across multi-step conversations
  • Producing answers that are more complete and grounded
  • Aiming to reduce the need for follow-up prompts and manual verification
In addition, Archie can now generate slide-style images to help summarise or visually present information.
Archie Word Add-in
You can now use Archie alongside Microsoft Word by installing the Smokeball Archie Word Add-in. This add-in contains many unique features dedicated to document review, and utilises the in-built Review feature in Word to help you draft documents and correspondence.
Learn how to install and use the Archie Word Add-in.
Create tasks, memos and events in Archie
Archie can now create tasks, memos and calendar events for your matter when prompted to. All actions require explicit user confirmation before execution.
Learn more about creating tasks, memos and events with Archie.
Ask Archie with your voice (Voice Dictation)
You can now use your PC's microphone to talk to Archie. Click on the microphone icon to start recording.
1 out of 1 found this helpful
