View all new features and refinements to Smokeball Bill and Boost for this month.
26th August 2026
[Smokeball Boost] The Archived conversations section is now available when using the new Messages UI.
20th August 2026
The Web App has been updated with a new logo!
- Failed charges on payment plans now give more descriptive error messages when you hover over them.
- Fixed a bug where Invoice Title, Subtitle and Notes in a matter's Invoice Settings reset to None after navigating away from and returning to Edit Matter.
11th August 2026
[Smokeball Boost + Intake] Smokeball Intake has been updated:
You can now customise the background colour of your Intake Forms as part of your firm's Branding Settings.
- Options include Default, Brand Color, White or Transparent. Use Transparent when the form is embedded on your website and you want it to blend into your existing page design.
- The background colour applies to all existing and new Intake Forms for your firm.
- Fixed an issue with a large blank space appearing in the generated PDF when a form includes multiple contacts in a group.
- Fixed an issue where changing a form's message templates was not triggering the publish modal.
- Fixed an issue where the checkbox and toggle box in Smokeball Settings > Intake Forms > General appeared cut off when selected.
- Fixed an issue where the "leave without publishing" modal remained on screen after the previous 'publish form' modal was closed.
6th August 2026
The Smokeball Web App has been updated with the following:
- Fixed an issue where hyphens could not be entered in Activity Codes in the Web App.
- Fixed an issue where staff with Invoice Read Only permissions could not send or download Invoice Adjustment Note PDFs.
The option to Send Via Client Portal has been added to the Invoice and Adjustment Note view.
