Components are the building blocks of a custom Intake Form. Learn what each Component is and how to use it.
To learn how to create and set up an Intake Form, go to Creating a custom Intake Form.
Mapped fields
A Mapped field component allows you to add fields that will be mapped back to that respective field in the lead or matter. To add mapped fields, expand on the categories listed under Available fields and tick the fields to add to the form:
Mapped fields are indicated by the orange diagram icon, which also tells you which field in the Smokeball lead or matter it is mapped to:
Group of fields
The Group of fields component is a handy way to cluster fields together.
One of the most useful features of using groups is the Repeat fields option. This is especially handy when you may have multiple of the same party type on a matter and need to collect identical information for each party.Â
When clients need to enter information for another contact, they can click Add and the fields will automatically duplicate for them.
To duplicate a group, select the Copy icon on the top-right corner of the group.
Text
The Text component allows you to add text to a particular area of the Intake Form.Â
Toggle on Include in saved record if you would like the text to be included in the downloaded/saved copy of the form.
Multiple Choice
The Multiple choice component allows respondents to choose multiple options from the list. Click on Add Choice to add a new option, and Add "Other" to add an option for "Other".
Single select
The Single select component allows respondents to choose one option from a list. Click on Add Choice to add a new option, and Add "Other" to add an option for "Other".
Short answer
The Short text component is where respondents can enter short-form text.
Long answer
The Long text component allows respondents to enter longer-form text, such as paragraphs.
Number
The Number component allows only numerical input and restricts any non-numerical input.
Note: Use the Phone number field if you are collecting phone numbers from the client.
Date
The Date component allows respondents to enter a date.
Currency
The Currency component requires respondents to enter a monetary value in the field.
Contact details
The Contact details component conveniently adds a group of contact-related fields to the form, without needing to add those fields one-by-one. Use the Applies to drop-down menu at the top of the component to choose the contact type the fields should map to.
Phone number
The Phone number component requires respondents to enter a phone number in the field. They cannot enter letters or symbols in this field, other than + (e.g. +44).
Address
The Address component requires respondents to enter an address in the field. Addresses entered in this field can be auto-completed using Google Maps:
The Email component requires respondents to enter an email address in the field.
Smokeball Payments
The Smokeball Payments component allows you to add a payment link to your intake form to receive Client Account payments as part of your intake process. Learn more about Smokeball Payments.
Appointment
The Appointment component allows clients to book specific staff members at designated times. The available staff and times can be configured to prevent double-booking. Scheduled appointments also sync with your staff members' Smokeball calendars for easy tracking. Learn more about setting up an Appointment component.
File upload
The File upload component allows respondents to attach any files to the form. There is a limit of 5 files, with a maximum of 128MB each.
Signature
Use the Signature component to add an area where the respondent can sign the form. You can choose from a free, basic signature, or a paid, cryptographically verifiable signature integrated through SignIT.
Learn more about adding a Signature component to Intake Forms.
