Mark a document as a favourite
Smokeball provides you with the ability to Favourite a document in your matter so you can locate it easily time and time again.
There is no limit to the number of documents you can set to Favourite.
Adding a document to Favourites
Smokeball Desktop App
You can identify a favourite document as it will have a yellow star in the corner of the document icon and when you hover over a document, the yellow star to the right side will light up.
Filter for favourite documents
To view only your favourite documents in a list, select the Favourites filter.
Additional tips
  • Changes to document favourites will show in the matter file and document history.
  • Favourited documents are firm-wide.
1 out of 3 found this helpful
