Importing documents, files and folders into a matter
Smokeball allows you to easily import any documents to a matter from any drive accessible by your computer.
Smokeball Desktop App Smokeball Web App
You can save both individual documents and folders from your computer to Smokeball, by simply using the Drag & Drop method, or utilising the Import function detailed below.
NB: If you import or drag & drop folders with sub-folders, Smokeball will maintain the folder structure.
  1. Navigate to a matter, then select Import in the Action bar.
  2. Choose either Files or Folders.
  3. Locate the files or folders from their computer location and click Open. You can select as many files or folders as you like at one time.
The documents or folders will appear in the bottom section of the matter file.
22 out of 37 found this helpful
