Updating previously saved documents
When you make changes to a matter in Smokeball, it won't automatically update any previously saved documents in your matter. This is because you might want to keep the original version of a historical document in many cases.
To update a previously saved document:
  1. After making the changes to a matter. Open an existing document from your documents list.
  2. Once open click anywhere along the Smokeball toolbar on the right of the page as highlighted below.
  3. Click on the update now and resume merge button. This will update all fields in the document.
  4. Once the document has finished updating you will be able to interact with the document again.
8 out of 19 found this helpful
