You can start your Smokeball journey by importing all essential contact and matter data from your previous legal software or other sources.
What can be imported?
- Staff Members
- Contacts
- Matters
- Matter Tags
- Matter Roles
- Matter Critical Dates
- Matter Archive Details
- Matter Account Balances
- Activity Codes
- Unbilled Time/Fee Entries
- Unbilled Cost Recovery Entries
- Invoices
- Billed Invoice Entries
- Memos
- Tasks
- Calendar Events
- Safe Custody
A full list of supported fields can be found here.
Step 1: Preparing your source data
Prepare your source data to ensure a smooth upload and import process. To get started:
- Export the above-listed data from your previous software into any of the following file types:
- CSV (comma-separated values)
- XLSX (Microsoft Excel 2007 and later)
- XLS (Microsoft Excel 97 to 2003)
- Follow the Preparing your source data for import article.
We recommend importing only relevant/active data, for example, minimising importing items such as "Closed" Matters and "Completed" Tasks where possible.
Step 2: Starting a new import
Once your data has been formatted as per the recommendations outlined in Step 1, you are ready to upload it to Smokeball.
- Select the gear icon in the lower-left corner of the Smokeball Web App, then select Data Import.
- Select New import.
- In the text box provided, select the system your data is coming from. If you can't find your system in the list, type a custom value, then select this option from the menu.
- Choose the items to include in the import, then click Proceed.
- Select Upload under the data you wish to import into Smokeball.
- Note: Some data types are unavailable (greyed out) until prerequisite data is uploaded and clear of errors.
- Selecting Cancel import will discard all data under this import, allowing you to start over.
Once an import has been started, it will appear on this screen as In-Progress.
You can come back to this at any time before submitting the import.
Step 3: Mapping columns
Once a file has been uploaded, it is time to map the columns you have in the file with Smokeball's data columns.
- Select the row that is the header row in your source data. This step will be skipped if the tool can automatically detect the header row.
- Click Next.
- You will now be presented with the Map columns window. Under the Destination Columns section, use the drop-down menu to select a suitable destination field for each uploaded column.
- The Sample Data column displays a preview of data from the corresponding column in the source data. (e.g. the Sample Data for the 'Last Name' column will extract Last Names from your source data).
- The tool may automatically map some columns that it thinks will match with your data. You can change this by choosing another option from the Destination Columns drop-down menu.
- Select Suggest mappings (not always available) at the top of the table to use AI-generated recommended mappings. We recommend reviewing the suggestions before proceeding.
- Click Next once done. You may only proceed if all Required Columns have been mapped.
An error message may appear if a required column has not been mapped, indicating the problem column that needs to be mapped.
If your source file does not contain a column that can be mapped to a "Required" Smokeball column, the following actions will need to be taken:
- Close the mapping view.
- Open your source data file (in Excel or similar) and add a column that can be used to map to the "Required" Smokeball column (the column name does not need to match the Smokeball column name).
- Re-upload the source file and proceed to map the columns.
Have issues with mapping columns? Review Preparing your source data for import to fix common pitfalls, then re-upload your file.
Step 4: Reviewing the uploaded data
Once mapping has been completed, all the data will be presented in a table. This view points out any validation issues in the data and allows you to edit the fields directly before saving the upload.
Any errors in the data are highlighted in red.
Any warnings in the data are highlighted in yellow.
The right-hand panel also shows a summary of all errors and warnings. Where a suggested fix is available, you can select Fix formatting errors to fix multiple errors in a column in bulk.
Click on the counter filter to filter the view by rows containing specific issues.
Click again to clear the filter and show all the data.
Some other useful tips to help navigate and edit data:
- Filter tabs to the top right of the data to show clean rows/rows with issues.
- "Find and Replace" button
- Keyboard shortcuts:
- Ctrl + Z = undo
- Shift + arrows = select cells
- Backspace or Delete = delete value from cell(s)
- Ctrl + F = find a value
Additional rows can also be added directly from this view using the "Add Row" Button.
From this screen, you can Save a file upload.
You can save with errors and warnings still present and, if required, come back to continue fixing later. All errors must be fixed before the overall import can be submitted.
The Data Import screen will show a summary of any errors and warnings still present in the data.
At this point, you are free to close the tool and resume the in-progress import later.
To make any further adjustments, select Edit to reopen the uploaded data.
Repeat the above steps for every data type you wish to upload.
Matters & Matter Types
If importing Matters, an additional selection is required when uploading your Matter source file to indicate if you are importing matters within your firm's country only, or also other countries (England/Scotland/Wales/Northern Ireland).
The selection made here will dictate the Smokeball Matter Types shown to you when you reach the Matter Type mapping stage, where you will map your input Matter Types to those supported in Smokeball.
When mapping your input Matter Types to Smokeball Matter types, some Smokeball Matter Types have multiple "acting for" options, for example, Remortgage - Borrower and Remortgage - Lender. Where this is the case, you will see various options available for selection in the Smokeball Matter Type dropdowns and can select the most suitable choice.
In the above example, "ENG" is the country, "Conveyancing" is the matter type category, "Remortgage" is the matter type, and "Borrower" is the "acting for" role.
TIP: When mapping matter types, expand the column widths to get a better view of the dropdown options.
Step 5: Previewing & Submitting the import
Once you have uploaded, mapped, and fixed all outstanding errors across all data to be imported, you can preview and submit the import using the Preview & Submit button in the top-right corner.
Preview gives you a holistic review of your prepared import data before you submit it to your account, covering Staff, Contacts, Matters & Matter Type Mapping, Financials, and more. Each of these is shown in its own interactive, searchable, and sortable view, so you can quickly find and check the records you care about. Items such as Matters, Contacts, Invoices, Tasks, and Memos also have a detailed view, showing the full record along with any associated or linked records. A financial summary is also included at both an import-wide and matter level, so you can confirm the numbers are what you expect.
Use Preview to check that the data is accurate and complete, and to catch anything wrong while it's still easy to fix. If something's not right, you can fix it directly within the import tool using the Edit button on that item, or correct your source file and upload it again. You can repeat this correction-and-review cycle as many times as you need before submitting the import.
A few import items are not yet previewable, including matter roles, matter tags, calendar events, and safe custody. If your import contains only items that are not yet previewable, you will see this submission confirmation pop-up, bypassing the ability to preview your import. Otherwise, you will be taken to the preview screen.
When you're ready to submit your import, click the Submit button in the top-right corner of the Preview screen. Then confirm in the confirmation prompt
Once an import is submitted, it cannot be reversed.
The import status will change from In-progress to Submitted.
Once the import has been validated, the status will change to Loading.
Then Complete, and your data now resides in Smokeball.
Clicking "View summary" will show a count of data included in the import, as well as allow you to jump into the preview screen for a more detailed view of the content in the import.
Troubleshooting
Validation
Once an Import has been submitted, if further validation issues are identified in the data, the status of the import will change to Failed Validation. A downloadable error file will be available to indicate the problem data, allowing you to re-open the current import, fix and any issues, then resubmit it.
Failed records
If an import completes but some records failed to load into Smokeball, the status of the import will be Complete and a downloadable error file will be available to indicate the failed records and reason for failure. Using the error file, a subsequent import can be performed for the failed records.
Unexpected
Once an Import has been submitted, if an unexpected system issue occurs, the status of the import will change to Failed Validation. If this is the case, please contact Support via the top right help (?) icon.
I need help with formatting and mapping my data.
Refer to Preparing your source data for import if you encounter any issues with mapping columns in the Data Import tool.
Supported Fields
Additional information and prerequisites for each data type can be found in Preparing your source data for import.
| Column Name | Required/Optional? | Notes |
Staff ID |
Required | This is a unique identifier used for a Staff Member. This ID will not be visible in Smokeball and is an internal identifier only. |
Title |
Optional |
First Name |
Required |
| Middle Name | Optional | |
Last Name |
Required |
Initials |
Optional |
Email Address |
Required |
Must be unique |
Current Staff |
Required |
Is the staff member current/active (yes/no) |
| Contact ID |
Required |
A unique identifier used for a Contact. This ID will not be visible in Smokeball and is an internal identifier only. |
| Type | Required | Must be a "Person" or "Company" (Firm/Business/Organisation). If not provided, where possible, this will be auto-populated. |
| Full Name | Optional |
This field should not be mapped in conjunction with First Name/Middle Name/Last Name. If used for mapping, the import tool will automatically split the full name out to First name, Middle name, Last name, or Company name. |
| Title | Optional | Title of the Contact |
| First Name | Required if Type is "Person" |
This field should not be mapped in conjunction with Full Name. Less than 200 characters. |
| Last Name | Optional |
| Company Name | Required if Type is "Company" |
For "Company" type records, the name of the contact goes here. For "Person" type records who are associated with a company/organisation, enter the associated company name here, as well as the person's name (in full name OR first/middle/last name). Less than 200 characters. |
| Doing Business As Name | Optional | Optional. Can be used if a Company contact has a business name that differs from the company name (trading as/practising as). |
| CRN | Optional | Company Registration Number (CRN) for a Company contact. |
| Job Title | Optional | Job Title of the Contact |
| Phone | Optional | Phone of the Contact (applicable to both `Person` and `Company` contacts). |
| Mobile Phone | Optional | Mobile Phone of the Contact (applicable to `Person` contacts only). |
| Work Phone | Optional | Work phone of the Contact (applicable to `Person` contacts only). |
| Business Fax | Optional | Business Fax of the Contact (applicable to `Company` contacts only). |
| Birthday | Optional | DD/MM/YYYY |
| Birth Place | Optional | The birthplace of the contact. |
| Birth Country | Optional | Birth country of the contact. |
| Date of Death | Optional | Date of death (DD/MM/YYYY) |
| Death Place | Optional | The place of death of the contact |
| Death Country | Optional | Death country of the contact |
| Gender | Optional | Gender of the Contact. |
| E-mail Address | Optional |
Can take multiple (; separated). Less than 255 characters. |
| Full Address | Optional | This field can be used if your input address data has multiple address parts (e.g. street/locality/town/county/post code/country) combined on one line/in the same cell. |
| Street Address Line 1 | Optional |
Simple format street address. If used for mapping, the import tool will automatically split the street address information out to the detailed format street address fields. These fields should not be mapped in conjunction with the detailed street address fields (property name, flat/unit, street num, street name, locality). |
| Street Address Line 2 | Optional | |
| Flat/Unit | Optional |
Detailed format street address. These fields should not be mapped in conjunction with the simple format street address fields (street address lines 1 and 2). |
| Property Name | Optional | |
| Street Number | Optional | |
| Street Name | Optional | |
| Locality | Optional | |
| City | Optional | Town/City for the Address |
| County | Optional | County for the Address |
| Post Code | Optional | Post Code for the Address |
| Country | Optional | Country for the Address |
| PO Box Number | Optional | PO Box Number - e.g. "123" |
| PO Box City | Optional | PO Box Town/City |
| PO Box Postal Code | Optional | PO Box Post Code |
| DX Address Number | Optional | DX Address Number. Only valid for Company contacts. |
| DX Address Exchange | Optional | DX Address Exchange. Only valid for Company contacts. |
| Full Registered Agent Address | Optional | Only valid for Company contacts. This field can be used if your input address data has multiple address parts (e.g. street/locality/town/county/post code/country) combined on one line/in the same cell. |
| Registered Agent Address Line 1 | Optional | Only valid for Company contacts. Simple Format: Street Address Line 1. This field should not be mapped in conjunction with the full registered agent address or detailed registered agent street address fields (property name, flat/unit, street number, street name, locality). |
| Registered Agent Address Line 2 | Optional | Only valid for Company contacts. Simple Format: Street Address Line 2. This field should not be mapped in conjunction with the full registered agent address or detailed registered agent street address fields (property name, flat/unit, street number, street name, locality). |
| Registered Agent Address Flat/Unit | Optional | Only valid for Company contacts. Detailed Format: Registered Agent Address Flat/Unit |
| Registered Agent Address Property Name | Optional | Only valid for Company contacts. Detailed Format: Registered Agent Address Property Name |
| Registered Agent Address Street Number | Optional | Only valid for Company contacts. Detailed Format: Registered Agent Address Street Number |
| Registered Agent Address Street Name | Optional | Only valid for Company contacts. Detailed Format: Registered Agent Address Street Name |
| Registered Agent Address Locality | Optional | Only valid for Company contacts. Detailed Format: Registered Agent Address Locality |
| Registered Agent Address Town/City | Optional | Only valid for Company contacts. |
| Registered Agent Address County | Optional | Only valid for Company contacts. |
| Registered Agent Address Post Code | Optional | Only valid for Company contacts. |
| Registered Agent Address Country | Optional | Only valid for Company contacts. |
| Full Forwarding Address | Optional | This field can be used if your input address data has multiple address parts (e.g. street/locality/town/county/post code/country) combined on one line/in the same cell. |
| Forwarding Address Line 1 | Optional | Simple Format: Street Address Line 1. This field should not be mapped in conjunction with the full forwarding address or detailed forwarding street address fields (property name, flat/unit, street number, street name, locality). |
| Forwarding Address Line 2 | Optional | Simple Format: Street Address Line 2. This field should not be mapped in conjunction with the full forwarding address or detailed forwarding street address fields (property name, flat/unit, street number, street name, locality). |
| Forwarding Address Flat/Unit | Optional | Detailed Format: Forwarding Address Flat/Unit |
| Forwarding Address Property Name | Optional | Detailed Format: Forwarding Address Property Name |
| Forwarding Address Street Number | Optional | Detailed Format: Forwarding Address Street Number |
| Forwarding Address Street Name | Optional | Detailed Format: Forwarding Address Street Name |
| Forwarding Address Locality | Optional | Detailed Format: Forwarding Address Locality |
| Forwarding Address Town/City | Optional | Forwarding Address Town/City |
| Forwarding Address County | Optional | Forwarding Address County |
| Forwarding Address Post Code | Optional | Forwarding Address Post Code |
| Forwarding Address Country | Optional | Forwarding Address Country |
| Forwarding Address PO Box Number | Optional | Forwarding Address PO Box Number |
| Forwarding Address PO Box Town/City | Optional | Forwarding Address PO Box Town/City |
| Forwarding Address PO Box Post Code | Optional | Forwarding Address PO Box Post Code |
| Forwarding DX Address Number | Optional | Only valid for Company contacts. |
| Forwarding DX Address Exchange | Optional | Only valid for Company contacts. |
| Notes | Optional | Notes for the Contact. |
| Additional Notes | Optional | This column can be used to map additional (one or more) input columns to the `Notes` field. All data mapped to this column will be combined into a single Notes field in Smokeball (separated by a new line). |
| Webpage | Optional | Web Page of the Contact. |
| Birth First Name | Optional | Birth first name of the contact (if not current name) |
| Birth Middle Name | Optional | Birth middle name of the contact (if not the current name) |
| Birth Last Name | Optional | Birth last name of the contact (if not current name) |
| Previous Names | Optional | Any previous names for the contact |
| Marital Status | Optional | The marital status of the contact |
| Special Needs | Optional | Special needs of the contact, e.g. wheelchair access, hearing or vision impairment. |
| VOI Completed | Optional | Indicate if the verification of identity is complete (Yes/No). Will default to No if left empty. |
| VOI Date | Optional | The verification of identity date (DD/MM/YYYY) |
| VOI Source | Optional | The verification of identity source, e.g., InfoTrack, Face to Face |
| VOI Reference | Optional | The verification of identity reference |
| Driver's Licence Number | Optional | Driver's Licence Number |
| National Insurance Number | Optional | National Insurance Number |
| NHS Number | Optional | National unique patient identifier |
| Country Of Citizenship | Optional | Country Of Citizenship |
| Nationality | Optional | Nationality |
| Language Of Interpreter | Optional | Language of interpreter (if applicable) |
| Passport Number | Optional | Passport Number |
| Passport Issue Date | Optional | Passport Issue Date (DD/MM/YYYY) |
| Passport Country Of Issue | Optional | Passport Country Of Issue |
| Passport Issuing Authority | Optional | Passport Issuing Authority |
| Passport Expiry Date | Optional | Passport Expiry Date (DD/MM/YYYY) |
| Bank Account Name | Optional | Bank details, account name for the contact |
| Bank Name | Optional | Bank details, bank name for the contact |
| Bank Sort Code | Optional | Bank details, sort code for the contact |
| Bank Account Number | Optional | Bank details, account number for the contact |
| Tags | Optional | Tags for the Contact. Accepts multiple (; separated) |
| Unique Company ID | Optional | This field is only relevant to Person Contacts and can be used instead of "Company Name" when there are multiple Companies in the import file with the same name, and you need to link one of them to a Person. |
| Matter ID |
Required |
Unique identifier used for Matter. This ID will not be visible in Smokeball and is an internal identifier only. |
| Matter Number / Reference | Optional | |
| Matter Description | Optional | |
| Matter Status | Required | |
| Branch Name | Optional | The Branch Office that the Matter relates to. Branch locations can be configured in the firm settings of your Account. Configured branches will then be available for selection. |
| Date Opened | Required | DD/MM/YYYY |
| Date Closed | Required if matter status = "Closed" | DD/MM/YYYY |
| Matter Type | Required | Matter Type as listed in your previous legal software. |
| Billing Type | Optional | Picklist of supported Smokeball Billing Types. |
| Supervisor Name or Email | Optional | Email address, name, or initials for the staff member to use as the Supervisor on the Matter. If supplied, the staff member must already exist in the account or be included in the Staff import file being imported. |
| Matter Fee Earner Name or Email | Optional | Email address, name, or initials for the staff member to use as the Fee Earner on the Matter. If supplied, the staff member must already exist in the account or be included in the Staff import file being imported. |
| Primary Person Assisting Name or Email | Optional | Email address, name, or initials for the staff member to use as the Primary Person Assisting on the Matter. If supplied, the staff member must already exist in the account or be included in the Staff import file being imported. |
| Other Person(s) Assisting Name or Email | Optional | Email address, name, or initials for the staff member(s) to use as the Other Person(s) Assisting on the Matter (accepts multiple, & separated). If supplied, the staff member must already exist in the account or be included in the Staff import file being imported. |
| Primary Introducer Name or Email | Optional | Email address, name, or initials for the staff member to use as the Primary Introducer on the Matter. If supplied, the staff member must already exist in the account or be included in the Staff import file being imported. |
| Other Introducer(s) Name or Email | Optional | Email address, name, or initials for the staff member(s) to use as the Other Introducer(s) on the Matter (accepts multiple, & separated). If supplied, the staff member must already exist in the account or be included in the Staff import file being imported. |
| Client ID or Email |
Required Can take multiple (separate entries with "&") |
Contact ID or Email of the Client for the Matter. Must exist in Smokeball, or the contact import file for the current import. |
| Other Side ID or Email |
Optional Can take multiple (separate entries with "&") |
Contact ID or Email of the Other Side for the Matter. Must exist in Smokeball, or the contact import file for the current import. |
| Other Sides Solicitor ID or Email | Optional | Contact ID or Email of the Other Sides Attorney for the Matter. Must exist in Smokeball, or the contact import file for the current import. |
| Debtor ID or Email | Optional | Contact ID or Email Address of the Contact to use as the default Debtor (accepts a maximum of three, & separated). A Contact with this ID or Email must exist in Smokeball, or the Contact import file for the current import. Populate if you wish to set the default debtor for future invoices to a contact other than the Client of the Matter. |
| Tags | Optional | Tags for the Matter. Accepts multiple (; separated). Tag colours will be applied at random during import, but can be edited later in Smokeball. |
| Archived | Optional | Indicate if the Matter is Archived (Yes/No). If set to 'Yes', archive and destroy dates are required. To be archived, the status of the Matter must be Closed or Cancelled. |
| Archive/Box Number | Optional | The archive or box number |
| Archive Location | Optional | The archive location |
| Archive Comment | Optional | Comments relating to the archive |
| Archived Date | Optional | The archive date (DD/MM/YYYY). Required if the Matter is marked as archived. |
| Destroy Date | Optional | The destroy date (DD/MM/YYYY). Required if the Matter is marked as archived. |
| Deleted | Optional | Defaults to "No" unless supplied otherwise. |
Matter ID or Number |
Required | The Matter ID or Number of the associated Matter. Must exist in Smokeball, or the matter import file for the current import. |
| Tags | Required |
Tags for the Matter. Accepts multiple (; separated). Note: Tag colours will be applied at random during import, but can be edited later in Smokeball. |
Contact ID or Email |
Required | Contact ID or Email of the Contact to use for the role. Must exist in Smokeball, or the contact import file for the current import. |
Role Name |
Required |
The name of the role (e.g. 'Child', 'Council' etc.). Depending on the Smokeball Matter Type chosen for each Matter, predefined supported roles will be available for selection, however, custom role names are also supported. |
| Date Field | Required |
The name of the critical date field. If the supplied field is not supported, a suggested list of supported critical dates will be provided based on the matter type for each matter. Supported fields can be browsed in the following report: Supported Date Fields Report |
| Date Value | Required |
The date for the corresponding critical date field (DD/MM/YYYY). |
| Archived | Required | Indicate if the Matter is Archived (Yes/No). If set to 'Yes', archive and destroy dates are required. To be archived, the status of the Matter must be Closed or Cancelled. |
| Matter ID or Number | Required | The ID or Number of the Matter associated with the Opening Balance. A Matter with this ID or Number must exist in Smokeball or the Matter import file for the current import. |
| Account Name |
Required Supported: Credit Account and any Client accounts configured in the firm. |
The account to import the Matter opening balance into. For Client accounts, in addition to the default account, you can configure multiple other accounts in the firm settings. Configured accounts will then be available for selection here. |
| Opening Balance (£) | Required | The opening balance amount (£) - e.g., "1500.50". Must be above zero |
| Opening Balance Date | Required | The opening balance date (DD/MM/YYYY). For Client accounts, as best practice, we recommend using the closing date from your previous system. |
| Code | Required | A code used for the Activity (between 2-5 characters). Must be unique. |
| Type | Required | The type of activity (Fixed Fee, Time Based, Cost Recovery). |
| Description | Required | A short description of the Activity. |
| Rate (£) | Required | The rate (£) of the Activity - e.g. "100.50" or "500.00" or "0.00" |
| Duration (Hours) | Required if Type = Time Based | If type = "Time Based", the duration of the Activity in hours - e.g. "1.0" or "1.5" or "2.0" (if not set, will default to 1.0 in Smokeball). |
| Quantity | Required if Type = Cost Recovery | If Type = "Cost Recovery", the quantity of the Activity - e.g. "1.00" or "1.50" or "2.00" (if not set, will default to 1.0 in Smokeball). |
| Cost Type | Optional |
If type = "Cost Recovery", indicate if the cost type is Hard or Soft (defaults to "Hard" in Smokeball if left empty). Hard costs are costs paid directly to the supplier, e.g. search fees. Soft costs are costs that your firm can choose to pass to the client, e.g. costs of printer paper and ink. |
| Matter ID or Number | Required | The ID or Number of the Matter associated to the entry. Must exist in Smokeball, or the matter import file for the current import. |
| Staff Name or Email | Required | Email address, name, or initials of the staff member associated with the entry. The staff member must already exist in the account or be included in the Staff import file being imported. |
| Date | Required | The date of the entry (DD/MM/YYYY) |
| Type | Required | The type of entry (Fixed Fee or Time Based). |
| Activity Code | Optional |
Optional. Must match a Code from an Activity Type in Smokeball, or the Activity Type import file for the current import. Assigning an activity code to an entry will not override/set other entry details (description, rate, duration etc). |
| Subject | Required | A short subject description of the entry. |
| Description | Optional | Description for the entry |
| Rate (£) | Required | The rate (£) of the entry - e.g. "100.50" or "500.00" or "0.00" (defaults to 0.00 if left empty). |
| Duration (Hours) | Required if Type = Time Based | If type = "Time Based", the duration of the entry in hours (allows 5 decimal places for precision). Must be equal to or above 0.01. |
| VAT Type | Required | Specify the VAT type for the item (VAT INC. / VAT EXCL. / VAT EXEMPT / VAT OUT OF SCOPE). |
| Billable | Required |
Yes/No. Indicate if the entry is billable (defaults to "Yes" if left empty). |
| Write Off | Required |
Yes/No. Indicate if the entry is written-off (defaults to "No" if left empty). |
Optional. Must match a Code from an Activity Type in Smokeball, or the Activity Type import file for the current import. Assigning an activity code to an entry will not override/set other entry details (description, rate, quantity etc). |
| Quantity | Required | The quantity of the entry - e.g. "0.50" or "1.50" or "2.00" |
| VAT Type | Required | Specify the VAT type for the item (VAT INC. / VAT EXCL. / VAT EXEMPT / VAT OUT OF SCOPE / VAT ZERO RATED). |
| VAT Override (£) | Optional |
Optionally specify a custom VAT amount for the item. This field is not applicable if the item is marked as ZERO RATED, OUT OF SCOPE, or EXEMPT from VAT, as a VAT override amount cannot be provided for these item types. For VAT EXCL. and VAT INC. items, if this field is left blank, the VAT amount will be calculated automatically using the default VAT rate configured in your account settings. If a custom amount is entered, it will be used as the VAT amount on the item. |
| Billable | Required | Yes/No. Indicate if the entry is billable (defaults to "Yes" if left empty). |
| Write Off | Required | Yes/No. Indicate if the entry is written-off (defaults to "No" if left empty). |
Indicate if the cost type is Hard or Soft (defaults to "Hard" in Smokeball if left empty). Hard costs are costs paid directly to the supplier, e.g. search fees. Soft costs are costs that your firm can choose to pass to the client, e.g. costs of printer paper and ink. |
| Anticipated | Required |
Yes/No. Indicate whether the item is a regular Cost Recovery or an anticipated Cost Recovery (defaults to "No" if empty). |
| Supplier ID or Email | Optional |
Required if the entry is anticipated or is supplier paid. Enter the ID or Email Address of the Contact to use as the supplier. The Contact must already exist in Smokeball, or be included in the Contacts import file for the current import. |
| Supplier Reference | Optional | Can be provided if the entry is anticipated, but becomes required once the entry is also supplier paid. |
| Supplier Payment Due | Optional | Required if the entry is anticipated (DD/MM/YYYY). |
| Supplier Paid | Required | Indicate if the entry is supplier paid (Yes/No). Defaults to "No" if empty. |
| Supplier Date Paid | Optional | Optional for anticipated entries that are not supplier paid. Required if the entry is supplier paid (DD/MM/YYYY). |
| Supplier Payment Method | Optional | The payment method used (Bank Transfer or Direct Debit). Required if the entry is supplier paid. |
| Supplier Account Name | Optional | Required if the entry supplier paid. |
| Supplier Payment Reference | Optional | Required if the entry supplier paid. |
| Invoice Number | Required | Must a be unique number with no leading zeros. |
| Debtor ID or Email | Required |
The ID or Email of the Contact who is the debtor on the Invoice (accepts multiple, & separated). Three maximum. Must exist in Smokeball, or the contact import file for the current import. |
| Matter ID or Number | Required | The Matter ID or Number of the associated Matter. Must exist in Smokeball, or the matter import file for the current import. |
| Issue Date | Required |
The Invoice Issue Date (DD/MM/YYYY). Will also be used as the date for Fee/Cost Recovery line items. |
| Due Date | Required | The Invoice Due Date (DD/MM/YYYY). |
| Title | Required | Title text for the Invoice. 255-character max. |
| Subtitle | Optional | Subtitle text for the Invoice. This will appear under the main Title. 255-character max. |
| Notes | Optional | Footer notes for the invoice. This text will appear at the bottom of the invoice. |
| Total Inc. VAT (£) | Required |
Overall Invoice Total. Must be above 0.00. Amount should be Inc VAT - e.g. "1500.50" or "800.00" or "123.00". |
| Fee Total Inc. VAT (£) | Required |
Fee portion amount. Should be Inc. VAT - e.g. "1500.50" or "800.00" or "0.00" or "123.00". |
| Fee Total VAT Exempt | Required |
Yes/No Indicate if the fee portion amount is exempt from VAT. Defaults to "No" if left empty, in which case VAT will be calculated based on the default VAT rate set in the settings of your Smokeball account. |
| Cost Recovery Total Inc. VAT (£) | Required |
Cost Recovery portion amount. Should be Inc. VAT - e.g. "1500.50" or "800.00" or "0.00" or "123.00". |
| Cost Recovery VAT Override (£) | Required |
Optional. Specify a custom VAT amount for the Cost Recovery portion. If left blank, VAT will be calculated automatically using the default VAT rate set in your Smokeball account settings. Entering 0.00 will mark the Cost Recovery portion as VAT Exempt. You can also enter a specific VAT amount (other than 0.00) to override the calculated VAT for the Cost Recovery portion. |
| Amount Due Inc. VAT (£) | Required |
Amount should be Inc VAT. Where Amount Due is less than the Total amount, a payment will be created and applied to the invoice automatically on import for the difference. |
| Payment Date | Required when the Amount Due is less than the Total Amount |
Required when the Amount Due is less than the Total Amount. A payment will be created and applied to the invoice automatically on import for the difference. |
Required. Each invoice must have an assigned owner — the staff member who created or finalised the invoice. Enter the email address, name, or initials of the staff member. The staff member must already exist in the account or be included in the Staff import file being imported. This will also be the staff member used for assignment of the Fee and Cost Recovery line items on the invoice. |
| Issue Date | Required | The Invoice Issue Date (DD/MM/YYYY). |
| Fee Discount (£) | Optional |
Discounting is an invoice-wide action. You can apply a flat amount discount to the time and fees portion of the invoice. Note: You cannot apply a discount to the cost recovery portion of an invoice. |
| Surcharge (£) | Optional | You can apply a surcharge by a flat amount on the invoice. |
| Surcharge Description | Optional |
Provide a custom surcharge description that will appear on the invoice (max 32 characters). Note: If left empty or not mapped, this will default to "Surcharge". |
Overall Invoice Total. Amount should be Inc VAT - e.g. "1500.50" or "800.00" or "123.00". |
Required. Each invoice must have an assigned owner — the staff member who created or finalised the invoice. Enter the email address, name, or initials of the staff member. The staff member must already exist in the account or be included in the Staff import file being imported. |
| Invoice Number | Required | The Invoice number associated with the item. An invoice with this number must exist in the Invoice import file for the current import. |
| Staff Name or Email | Required | Email address, name, or initials of the staff member associated with the item. The staff member must already exist in the account or be included in the Staff import file being imported. |
| Date | Required | The date of the item (DD/MM/YYYY) |
| Type | Required | The type of the item (Fixed Fee, Time Based, Cost Recovery). |
| Subject | Required | A short Subject description of the item. |
| Rate (£) | Required | The rate (£) for the item - e.g. "100.50" or "500.00" or "0.00". |
| Duration (Hours) | Required if type = Time Based | If type = "Time Based", the duration in hours (allows 5 decimal places for precision). Must be equal to or above 0.01. |
| Quantity | Required if type = Cost Recovery | If type = "Cost Recovery", the quantity - e.g. "1.00" or "1.50" or "2.25" (must be equal to or above 1.00) |
Optionally specify a custom VAT amount for cost recoveries. This field is not applicable if the item is marked as ZERO RATED, OUT OF SCOPE, or EXEMPT from VAT, as a VAT override amount cannot be provided for these VAT types. For VAT EXCL. and VAT INC. items, if this field is left blank, the VAT amount will be calculated automatically using the default VAT rate configured in your account settings. If a custom amount is entered, it will be used as the VAT amount on the item. |
| Write Off | Required | Indicate if the item is written-off (defaults to "No" if left empty). |
| Anticipated | Required If type = "Cost Recovery" |
Yes/No. If type = "Cost Recovery": Indicate whether the item is a regular Cost Recovery or an anticipated Cost Recovery (defaults to "No" if empty). |
If type = "Cost Recovery": Required if the entry is anticipated or is supplier paid. Enter the ID or Email Address of the Contact to use as the supplier. The Contact must already exist in Smokeball, or be included in the Contacts import file for the current import. |
| Supplier Reference | Optional | If type = "Cost Recovery": Can be provided if the entry is anticipated, but becomes required once the entry is also supplier paid. |
| Supplier Payment Due | Optional | If type = "Cost Recovery": Required if the entry is anticipated (DD/MM/YYYY). |
| Supplier Paid | Required If type = "Cost Recovery" | If type = "Cost Recovery": Indicate if the entry is supplier paid (Yes/No)—defaults to "No" if empty. |
| Supplier Date Paid | Optional | If type = "Cost Recovery": Optional for anticipated entries that are not supplier paid. Required if the entry is supplier paid (DD/MM/YYYY). |
| Supplier Payment Method | Optional | If type = "Cost Recovery": The payment method used (Bank Transfer or Direct Debit). Required if the entry is supplier paid. |
| Supplier Account Name | Optional | If type = "Cost Recovery": Required if the entry supplier paid. |
| Supplier Payment Reference | Optional | If type = "Cost Recovery": Required if the entry supplier paid. |
| Memo ID | Required | Unique ID for the Memo. This ID will not be visible in Smokeball and is an internal identifier only. |
| Matter ID or Number | Required | Required for all Memos. The Matter ID or Number of the associated Matter. Must exist in Smokeball, or the matter import file for the current import. |
| Date & Time | Required |
Memo date & time (24-hour). Not visible in Smokeball Web but retained for historical reference. If not populated, will default to the date of upload (DD/MM/YYYY HH:MM). E.g. 05/08/2024 14:30 |
Subject of the Memo (If not populated, where possible, the first 50 characters of the memo text will be used). Maximum 200 characters. |
| Text | Required | Full Memo text (If not populated, where possible, the subject of the memo will be used). |
| Created By Staff Name or Email | Required | Email address, name, or initials of the staff member who created the Memo. The staff member must already exist in the account or be included in the Staff import file being imported. |
| Task ID | Required | Unique identifier for the Task. This ID will not be visible in Smokeball and is an internal identifier only. |
| Matter ID or Number | Optional | The Matter ID or Number of the associated Matter (optional). If supplied, must exist in Smokeball, or the matter import file for the current import. |
| Name | Required | Name of the Task |
| Description | Optional | Task description (max 8,000 characters) |
| Status | Required | Task Status (Complete or Incomplete) |
| Created Date | Required | Date the Task was created (DD/MM/YYYY) |
| Created By Staff Name or Email | Required | Email address, name, or initials of the staff member who created the Task. The staff member must already exist in the account or be included in the Staff import file being imported. |
| Assignee Staff Name or Email | Optional | Email address, name, or initials of the staff member to use as the Task assignee (accepts multiple, & separated). If supplied, the staff member must already exist in the account or be included in the Staff import file being imported. |
| Due Date | Optional | Due date of the Task (DD/MM/YYYY) |
| Completed Date | Required if status is "Complete" | The completion date of the Task. Required if Status = Complete (DD/MM/YYYY) |
| Completed By Staff Name or Email | Required if status is "Complete" | Email address, name, or initials of the staff member who completed the Task. Required if Status = Complete. If supplied, the staff member must already exist in the account or be included in the Staff import file being imported. |
| Duration | Optional | Duration of the Task (MM or HH:MM) - e.g. "01" or "15" or "1:30" or "01:06". |
| Event ID | Required | Unique identifier for the Event. This ID will not be visible in Smokeball and is an internal identifier only. |
| Subject | Required | Name of the Event (255 character maximum). |
| Location | Optional | The Event location (255 character maximum). |
| Comments | Optional | Additional comments or description for the Event. |
| Created By Staff Name or Email | Required | Email address, name, or initials of the staff member who created the Event. The staff member must already exist in the account or be included in the Staff import file being imported. |
| Attendee Staff Names or Emails | Required or Group Calendar Name |
Accepts multiple & separated. Each Event must have at least one Staff Member or Group Calendar as the Assignee (or both). For Staff, enter the email address, name, or initials of the staff member. The staff member must already exist in the account or be included in the Staff import file being imported. Note: An attendee’s Calendar Event will only be visible in the application once imported if they are an active paying user or a former Staff member. |
| Group Calendar Name | Required or Attendee Staff Emails |
Accepts multiple, & separated. Each Event must include at least one Group Calendar or Staff attendee (or both). |
| All Day Event | Required | Indicate if the Event is all day (Yes/No). |
| Start Date & Time | Required | The start date and time (24-hour) of the Event (DD/MM/YYY HH:MM). Note: Smokeball does not allow bulk imports of events more than two years old. |
| End Date & Time | Required | The end date and time (24-hour) of the Event (DD/MM/YYY HH:MM). Must be equal to or greater than Start Date Time. |
| Time Zone | Optional |
Optional: Time zone for the Event in IANA format (e.g. 'Europe/London'). By default, the firm address set in the Smokeball settings will be used to determine the time zone for the event. This can be overridden if needed by providing a value in this column. |
Indicate if the Event is Billable (Yes/No). All day Events or Events longer than 12 hours cannot be marked as Billable. |
| Contact ID or Email | Required | The ID or Email of the Contact associated to the Packet (accepts multiple, & separated). Must exist in Smokeball, or the contact import file for the current import. |
| Packet Number | Required | The unique Packet reference number. Must be a unique number above zero. |
| External Ref. | Optional | Similar to Packet Number, but can cater for data from systems that do not conform to Smokeball validation requirements. If the Packet Number field cannot be used (due to validation concerns - e.g. duplicates, non-numeric values), this field can be used as an alternative and the Packet Number can be sequential numbering. |
| Storage Location | Required | The Packet storage location. |
| Notes | Optional | Notes for the Packet. |
| Created By Staff Name or Email | Required | Email address, name, or initials of the staff member who created the Packet. The staff member must already exist in the account or be included in the Staff import file being imported. |
| Created Date | Required | The date the Packet was created (DD/MM/YYYY). |
| Packet Number | Required | The Packet Number of the associated Packet. This Packet Number must exist in the Safe Custody Packet import file for the current import. |
| Document Type | Required | The type of Document - e.g. Birth Certificate |
| Document Number | Required | The unique document reference number per Packet. Must be a unique number above zero. |
| External Ref. | Optional | Similar to Document Number but can cater for data from systems that do not conform to Smokeball validation requirements. If the Document Number field cannot be used (due to validation concerns - e.g. duplicates, non-numeric values), this field can be used as an alternative and the Document Number can be sequential numbering. |
| Description | Required | Description for the Document. |
| Status | Required | The status of the Document (Held / Removed / Retrieved). |
| Reason | Optional | Reason/notes. For example, a reason why the Status is marked as Removed, Retrieved. |
| Received Date | Required | The date the Document was received (DD/MM/YYYY). |
| Last Movement Date | Required if the status of the Document is Removed/Retrieved. | The date of the last document movement (DD/MM/YYYY). Required if the status of the Document is Removed/Retrieved. |
| Created By Staff Name or Email | Required | Email address, name, or initials of the staff member who added/last updated the Document. The staff member must already exist in the account or be included in the Staff import file being imported. |
