Smokeball System Requirements
Here are the recommended system requirements for optimal Smokeball performance. If your setup doesn't meet them, it may affect your experience. Consult an IT professional for further steps.
Smokeball Grow/Prosper+
The Smokeball native (desktop) app must be locally installed for Smokeball Grow and Prosper+ users.
Recommended System Requirements
Operating System
Windows 11 (64-bit)
32-bit Windows is not supported.
CPU Processor
3.0 GHz Intel i5 processor or equivalent
Recommended RAM
16GB
Minimum RAM
8GB
Storage
5GB of free hard disk space on the C: Drive
Software
Microsoft Office 365 for Business (locally installed on the machine) and set to the Monthly Enterprise Channel
Network
Broadband Internet Connection
Resolution
1280 x 1024 pixel, full HD display
Web browser
Google Chrome or Microsoft Edge
Antivirus
Microsoft Defender
We recommend Microsoft Defender, a reliable and free antivirus solution. Other antivirus products may affect the performance of Smokeball.
Operating System Requirements
We do not recommend running Smokeball on the following systems:
ARM/Snapdragon Processors Unsupported - while Smokeball can run on ARM processors, features such as Print to Smokeball PDF will not work.
Mac OS Unsupported
Terminal Server Unsupported
Windows 7 Unsupported
Windows 10/10S Unsupported
Microsoft Office Requirements
Smokeball should be installed on a system that contains a locally installed version of Microsoft Office (Word, Outlook and Excel).
We recommend switching to the Monthly Enterprise Channel to minimise the impact of bugs introduced in the latest Microsoft Office updates that affect Smokeball features. This may have to be administered by your firm's IT.
Smokeball user machines should only be running one version, copy or license of Microsoft Office. Machines running multiple copies of Office are not supported.
We do not recommend running Smokeball with the following Office products:
Office Online and Browser-based Office 365 Unsupported, unless you would like to use the New Outlook integration, which is accessed via Outlook on the web.
Office Home & Student Unsupported
Microsoft Office 2013/2016/2019 Unsupported
Outlook Account Requirements
Refer to the table below on the types of Outlook accounts that can and cannot connect to Smokeball:
Microsoft accounts hosted by GoDaddy
Supported on New Outlook
Unsupported on Classic Outlook
Non-Outlook (e.g. Gmail, Yahoo) accounts logged into Outlook Unsupported
Personal Outlook, Hotmail, Live accounts Unsupported
Important Information
  • Third-party software, legacy software and/or software add-ins may interfere with Smokeball's performance.
  • Smokeball user machines should only be running one version, copy or license of Microsoft Office. Machines running multiple copies of Office are not supported.
  • We recommend Microsoft Defender, a reliable and free antivirus solution. Other antivirus products may affect the performance of your computer/Smokeball.
  • Smokeball only supports desktop scanners that are locally connected.
Smokeball Diagnostics Tool
You can also download and install the Smokeball Diagnostics Tool on your PC to scan for any compatibility issues with Smokeball.
Access the Smokeball Diagnostics Tool.
74 out of 106 found this helpful
