Learn how to seamlessly integrate Legalito with Smokeball to streamline your conveyancing process. This integration allows you to manage pre-contract enquiries more efficiently by providing a secure, fully electronic platform for communication between law firms, helping to reduce delays and errors in enquiries.
You can learn more about Legalito by visiting their website: https://legalito.co.uk/
Connecting Smokeball to Legalito
Follow these steps to connect your Smokeball account to Legalito and begin managing enquiries.
- Log in to Legalito Smart Enquiries and click on your user icon.
- Select Settings from the dropdown menu.
- Navigate to the Integrations tab on the Settings page.
- Find Smokeball in the integrations and select Connect.
- Enter your Smokeball credentials and select Sign in.
Once you complete these steps, the integration will be connected and you're ready to start using Legalito with Smokeball.
Â
Using Legalito with Smokeball
Watch our introductory video to learn more about using Legalito with Smokeball:
Connect matters from Smokeball
You can easily create a Legalito matter linked to an existing Smokeball matter by following these steps:
- In Smart Enquiries, click on Create matter.
- Your active Smokeball matters will appear on the Create Matter screen. Use the search box to find the relevant Smokeball matter, then select Import.
- The details from your selected Smokeball matter will be automatically imported into your Smart Enquiries dashboard, ready to start raising enquiries.
Â
Upload documents from Smokeball matters
When raising enquiries, you can easily upload any document from your linked Smokeball matter.
- In the enquiry screen, select Upload file(s).
- Select Import from Smokeball to access the files saved in your linked Smokeball matter.
- Select the document(s) you want to upload, then select Import selected document.
Smart Enquiries automatically saved to Smokeball
When you raise Smart Enquiries on a linked matter, the system will automatically save them as a file in your Smokeball matter. These will be saved in a Smart Enquiries folder on your matter.
Replies to enquiries will automatically sync back to Legalito, as well as automatically updating the enquiry document saved in your Smokeball matter.
