Aquarius Reporting
About Aquarius Reporting
Aquarius Reporting is a specialised business intelligence and analytics solution designed for law firms. It transforms Smokeball data into clear, actionable dashboards and reports that support informed decision-making across the firm.
  • In Depth Reporting: Aquarius delivers comprehensive, detailed financial and operational management reports.
  • Power BI Integration: Aquarius is built on Microsoft Power BI, a system that offers scalable, secure, and industry-standard reporting functionalities, enhancing performance and data management.
  • Security & Data Protection : With Aquarius, your data always remains your data. The system runs in your Microsoft environment, ensuring information never leaves your control. It offers multiple layers of access control: from login credentials to app permissions, tailored audiences, and row-level security.
  • Expert Advisory Service: Aquarius provides an Expert Advisory Service which helps firms bridge the gap between raw data and meaningful.
Requirements for Aquarius Reporting integration
  • An active Smokeball account
  • A nominated Smokeball user with permission to approve third-party integrations
  • A Microsoft 365 account with a Power BI Pro licence to host Aquarius reports
Power BI Credentials
  • A Microsoft 365 account will need to be created for set up, deployment and ongoing management of the solution.​
  • Recommended format: PowerBI@[clientdomain].co.uk ​
  • This Entity will require:​
    • Read-Only Access to the Case Management ​and/or Finance System Database(s)​
    • A Power BI Pro License – More info here​
  • This account will own the Aquarius datasets, reports, and Power BI App for the firm
Tenancy Settings
The PowerBI@[clientdomain].co.uk will need to have permission to create workspaces. This can also be given to the entire organisation as seen below:
Azure Maps also need to be enabled, as Aquarius uses these maps in multiple reports:
Setup Steps
  1. To set up the Aquarius Reporting integration, the firm must complete a one-time authorisation process. In this purpose Aquarius provides a secure authorisation link to the firm
  2. The nominated user clicks the link and is redirected to Smokeball
  3. The user logs in using their Smokeball credentials
  4. Authorisation is completed and data syncing begins automatically
After Authorisation
Once the integration is authorized:
  • Aquarius securely retrieves data from Smokeball on a scheduled basis
  • Data is processed and loaded into Power BI Service
  • Aquarius dashboards and reports are published as a Power BI App
  • Firm users can access reports via Power BI based on their permissions
Support
For assistance with Aquarius Reporting or the Smokeball integration, please contact the Aquarius support team support@drghills.co.uk
1 out of 1 found this helpful
