Learn how to connect Smokeball to Odella (formerly known as Lawme), an AI-powered workforce factory for automating tasks, research and document drafting.
To find out more about Odella and book a demo, get in touch with the team via their website.
Connecting Smokeball to Odella
- Log in to your Odella account and select Integrations from the left menu.
Toggle on Smokeball from the list of integrations.
- Follow the prompts to log in to your Smokeball account in order to authenticate the connection.
Using the Odella Integration
Once Smokeball is connected to Odella, you can connect Smokeball data to a Workflow in Odella, for your AI employee to follow.Â
These Workflows can be as simple or complex as you need, even incorporating Odella's Templates to draft documents using AI.
You can also direct your AI employee to look up Smokeball matter data via the Chat feature.
Getting support for the Odella Integration
If you need assistance with connecting Smokeball to Odella, or to get started with using Odella, contact the Odella team on their website: https://www.odella.ai/Â
Â
