Learn how to connect Smokeball to Lawme, an AI-powered workforce factory for automating tasks, research and document drafting.
To find out more about Lawme and book a demo, get in touch with the team via their website.
Connecting Smokeball to Lawme
- Log in to your Lawme account and select Integrations from the left menu.
Toggle on Smokeball from the list of integrations.
- Follow the prompts to log in to your Smokeball account in order to authenticate the connection.
Using the Lawme Integration
Once Smokeball is connected to Lawme, you can connect Smokeball data to a Workflow in Lawme, for your AI employee to follow.Â
These Workflows can be as simple or complex as you need, even incorporating Lawme's Templates to draft documents using AI.
You can also direct your AI employee to look up Smokeball matter data via the Chat feature.
Getting support for the Lawme Integration
If you need assistance with connecting Smokeball to Lawme, or to get started with using Lawme, contact the Lawme team on their website: https://www.lawme.ai/Â
Â
