Learn how to use Smokeball with Umango, allowing you to export job documents from Umango into Smokeball.
Before you begin
Ensure you have connected your Smokeball firm to Umango. Refer to Umango's listing on the Smokeball Marketplace or the Umango website for more information.
Using the Umango Integration with Smokeball
Watch the comprehensive video below on how to connect your Umango job to Smokeball.
Getting support for the Umango Integration
If you need help with the Smokeball and Umango integration, or with using Umango, get in touch with your Umango solution partner.
