Display a professional fee summary on an invoice
You can add a professional fee summary to all your invoices or on a per-invoice basis. Read on to learn more.
Display a professional fee summary on all invoices
  1. Select the gear icon to open Smokeball Firm settings.
  2. Select Invoice Settings, choose your template, and then select the PDF Invoices tab.
  3. Scroll down to Display Options > Supplementary Tables and then select Show professional fee summary.
    • You can also display the timekeeper’s role on the summary.
Display a professional fee summary on a single invoice
  1. Select Edit Invoice Options on a draft invoice.
  2. Select Show Professional Fee Summary.
The image below is an example of how a professional fee summary will appear on an invoice with the role option enabled:
1 out of 1 found this helpful
