Save an invoice to a matter
If you need to save an invoice to your matter's documents section in the Smokeball desktop app, there are two ways to do so:
Download invoices from the web app
  1. Navigate to the Invoices view
  2. Sort the invoices by debtor
  3. Select the invoices you need to save using the checkboxes
  4. Select download
  5. Upload the downloaded invoices to your matter
Use an administrative matter
  1. Create a matter that is purely for storing all of your invoices
  2. Download all the invoices you wish to save and use the Print to Smokeball PDF feature to save it to the administrative matter
    • Note: You can choose to create a firm-wide administrative matter or administrative matters for each attorney
0 out of 2 found this helpful
