Create a Client Statement
If you have a client who has multiple matters with your firm, you can issue a Client Statement that will combine multiple invoices into a single statement. Payments can then be applied to all the invoices on the Client Statement in a single action.
Issue a Client Statement
  1. While in the web app, navigate to the Contact and select Invoices.
  2. Use the checkboxes to select the invoices you wish to combine into a Client Statement.
  3. Select Create Statement from the Bulk Actions dropdown menu.
  4. The Client Statement preview will open in a new tab in the web app.
  5. Select the Add Payment button to apply a payment to the invoices on the client statement. Select the Email button to send the client statement to your client.
View and Void Client Statements
You can find and re-open a Client Statement by using the Statement column on the Invoices tab of the Contact.
You can select the Void button on a client statement to void it. Note: There is no option for editing client statements.
4 out of 15 found this helpful
