Change default sender email address when starting emails from Smokeball
To change the default sender email address, you first need to change the Outlook default data file to the business account. Follow the steps below:
  1. Open Outlook.
  2. Select File in the top left corner.
  3. Select Account Settings and then select the Account Settings... option from the dropdown menu.
  4. Navigate to the Data Files tab.
  5. Select the email that you want as a default.
  6. Select the Set as Default button.
  7. Close and then re-open Outlook.
  8. Start an email from Smokeball. It should go to the email you selected as default data file.
2 out of 7 found this helpful
