Discounting is an invoice-wide action which is applied before the invoice is finalized. You can choose to apply a discount by a flat dollar amount or percentage to time and fees on the invoice. Note: You cannot apply discount to expenses on an invoice.Â
- Open the draft invoice.
 - Select Apply discount on fees.
 - Select which type of discount to apply using the $ toggle or % toggle.
 - Select the green checkmark to apply the discount.
Â
 - You will now see the discount applied beneath the subtotal. If you wish to change or remove the discount, select the pencil icon. De-select Apply discount on fees if you wish to remove the discount entirely.
 - Select Save Draft.
You can also apply a surcharge to your invoices.Â
