Add and edit custom referral types
By default, Smokeball features a wide variety of referral types. However, you can also add custom referral types to best reflect how referrals impact your business.
Note: You must be a firm owner to access referral types.
Add a new custom referral type
  1. Navigate to Smokeball Settings and select Referral Types.
  2. Enter the name of the new referral type in the designated field.
  3. Select Add.
  4. Select Save.
The new referral type will now appear in the list below in alphabetical order.
Edit a custom referral type
  2. Locate the custom referral type you need to edit and select the pencil icon.
  3. Save your changes by selecting the checkmark icon.
  4. Select Save.
Delete a custom referral type
  2. Locate the custom referral type you need to delete and select the garbage can icon.
  3. Confirm that you wish to delete the referral type when prompted.
  4. Select Save.
Restore a deleted custom referral type
Deleting a custom referral type is not permanent. You can restore a deleted custom referral type by:
  1. Selecting the Show deleted referral types checkbox.
  2. Locate the deleted custom referral type from the list. Deleted referral types will be noted in
    italics and grey.
  3. Select the Restore icon.
Note: If you delete a referral type that is linked to a matter or lead, it will stay assigned to the matter but be indicated in italics and grey.
Access referral types from a matter
You can quickly access Smokeball Settings > Referral Types from the Matter info window and then selecting the cog wheel icon next to Referral Type.
3 out of 6 found this helpful
