Use Boolean search for documents
Learn how to use Boolean search operators such as "and," "or," and "not" to refine your document search results.
Important note: If you toggle Boolean search on, you will only be able to search for documents. Toggle Boolean search to off if you need to search for leads, matters, contacts, events, tasks, or memos.
To use Boolean search:
  1. Select Search from the left column.
  2. Toggle Boolean Search on.
  3. Enter your search using a Boolean operator (see the chart below).
List of Boolean operators and their functionality
What it does
Example
AND
Return results that match on BOTH connected terms/phrases
apples AND oranges
This search term will return documents that contain both of these terms within
OR
Return results that match on EITHER of the terms/phrases
apples OR oranges
This search term will return document that contain 1 or both of the requested terms
NOT
Removes results that contain the following term/phrase
apples NOT oranges
This search term will return documents that match on “apple” but remove matches that also contain “oranges” within
Allows wildcard matching (partial search terms)
app*
This search term will return any document that contains the term “app…” followed by any characters. I.e. Apple, Application, Apply etc
Allows term/phrase grouping when using multiple operators
apples AND (oranges OR bananas)
This search term will return documents that contain the both apple and orange OR apple and banana
Indicates an exact match is required for the containing phrase
“apple banana”
This search term will return documents that contain “apple banana” in that exact placement
41 out of 45 found this helpful
