Delete Documents
Smokeball Grow/Prosper+ Smokeball Web App
It is possible to delete a file from any matter by right-clicking on the item. However, nothing is ever permanently deleted, and you can restore any file deleted accidentally.
Delete a file
Right-click any document and select Delete or select and use the Delete hotkey.
Restore a deleted file:
Right-click under documents and select Show deleted items.
Locate the deleted file, right-click, and select Restore.
32 out of 51 found this helpful
