Create a secure PDF from Smokeball
By default, PDFs created from documents within a matter are not password protected. If you wish to assign a password to a PDF you create from your matter, follow these steps:
  1. Right-click on the document you wish to turn into a PDF and select Create multiple file PDF.
  2. On the Select files for PDF file popup window, select the Make PDF secure checkbox.
  3. Click on the three vertical dots next to the Make PDF secure checkbox
  4. Enter the file's password in the Read Password field. Enter the password again in the Confirm Password field.
  5. Name the secure PDF file.
  6. Select Create.
The created secure PDF can only be opened with the designated password.
4 out of 5 found this helpful
