Save documents, webpages or images to a matter using Print to Smokeball PDF
If you need to save a document, webpage, or image to a matter which originated outside of Smokeball, follow these steps:
  1. Open the file in an appropriate Windows application (e.g., Windows Photos, Adobe Reader).
  2. Right-click on the open file or webpage and select Print or select Ctrl+P.
  3. Select Print to Smokeball PDF in the Print menu and then select Print
  4.  Name the file in the Save to Smokeball pop-up window. Use this window to also choose which matter and documents folder to save the file to.
Once saved, you can access the new PDF in the documents folder you specified.
In addition to common PDF applications such as Adobe Reader, you can save a PDF file to Smokeball from virtually anywhere that allows for printing in Windows, such as a web browser.
You also have the option of importing an external PDF file to your matter.
FAQ:
Q: What should I do if I cannot see the Print to Smokeball PDF option?
A: If your Smokeball is up-to-date and you cannot use this option after following the steps above, please reach out to our support team for assistance.
42 out of 58 found this helpful
