RECORD Integration
RECORD is a novel app that uses automated data collection, treatment tracking, and client communication to improve personal injury case management. All data collected in RECORD is sent back to Smokeball. In addition to centralizing case information and easing rote administrative work, you can use RECORD to send clients automated reminders and notifications about treatment plans.
Learn more about RECORD.
Benefits of RECORD
  • Collect and organize client information with ease
  • Use automated reminders and notifications to keep clients on track
  • Quick and secure communication with your clients
  • Automate routine tasks
  • A client-friendly platform which enables them to monitor their case progress and stay informed.
  • Take advantage of detailed data collection and improved client adherence to treatment plans to boost case value.
Set Up RECORD
  1. Log in to Smokeball with your username and password.
  2. Open Firm Settings and select Integrations.
  3. Select RECORD integration.
  4. Follow the prompts to authorize the integration. You will need to grant permission to share data between Smokeball and RECORD.
  5. Customize your integration settings to best suit your workflow.
  6. Select Save to activate the integration.
Get support for RECORD
If you would like to try RECORD before purchasing a subscription, you can request a demo.
If you have any difficulty in setting up or using this integration, reach out to RECORD by email (support@recordclient.com) or phone (866)-706-7273.
You can also submit feedback and suggested improvements for RECRD by sending an email to feedback@recordclient.com or completing the feedback form available at recordclient.com.
