AcroDocz
AcroDocz is an AI software which analyzes medical records and medical bills from your matters. Once the review is complete, a summary is generated and saved back to the matter. This integration considerably streamlines the review process for these types of documents.
Set Up AcroDocz
  1. Navigate to Smokeball Settings.
  2. Select the Integrations tab.
  3. Select AcroDocz.
  4. Select the Authorize button.
  5. Select Save.
 Use AcroDocz
  1. Navigate to AcroDocz's order page.
  2. Enter your credentials into all the required fields.
  3. The Document section should now allow you to search for your Smokeball matters.
  4. Select the documents you need analyzed from the dropdown menu and the summary type.
  5. Verify that you read and agreed to the Terms and Conditions of Use.
  6. Select the Submit button.
You will receive a confirmation email after submission with a payment link to the summary. Click on the link to complete the transaction and download the summary.
Additional Support
If you need additional assistance in setting up AcroDocz, send their support team an email.
