Smokeball partners with Briefpoint to use pioneering AI technology to generate discovery requests and responses which can be saved to your Smokeball matter.
Learn more about Briefpoint on their website.
Connect Briefpoint to Smokeball
- Navigate to https://briefpoint.ai and then select Login to create an account.
- After you create your account, select Connect to CMS.
- Select Smokeball.
Note: Smokeball users can trial Briefpoint for free. After the trial expires, you can continue using Briefpoint by paying for each document generated or an unlimited subscription plan.
Using Briefpoint
After Briefpoint is connected, select the destination matter folder for the documents generated by Briefpoint.
We recommend watching the videos below to learn Briefpoint fundamentals:
Get support for your Briefpoint integration
For further assistance with setting up Briefpoint to work with Smokeball, refer to Briefpoint's FAQ article or email support@briefpoint.ai.
