Criminal Forms
Proprietary Documents to Submit for Client Automation
Illinois Court and Authority Forms
California Court and Authority Forms
Smokeball can help generate your proprietary letters and documents quickly and accurately from our Forms and Templates Library. Below are some popular forms to submit or work with your Account Manager to automate in Smokeball:
  • Client Correspondence
    • Update/Status Letter
    • Closing Letters
  • Appearance
  • Discovery
    • Request for Production of Documents and Other Things
  • Motions/Notices
  • Subpoenas
Illinois Court & Authority Forms
Smokeball has a variety templates to use such as Appearance, Motions, etc. You can find them under the default folders in the Forms and Templates Library.
  • Subpoena Duces Tecum (CCCR 0066)
  • Appearance (CCCR N114)
  • Affidavit in Support of Petition to Expunge or Seal (CCCR 0328)
  • Motion to Quash Arrest
  • Motion for Discovery
California Court & Authority Forms
Smokeball's Forms & Templates library is a place to find all your templates including letters and court and authority forms. Depending on which state you are located, you may find your forms in different folders. When you open the forms/templates library in California, you will see some shortcuts saved in your default folders.
Smokeball also includes California's Judicial Council Forms and Local County Forms. If there is a Judicial or Local County form that is not available, Smokeball's Content team will add it to the library for use.
0 out of 3 found this helpful
