With Smokeball's integration with ScanSnap, it is possible for you to scan documents and have them be saved directly to a matter. Follow this quick setup guide and start scanning today!
If you are using a new version of ScanSnap called ScanSnap Home, refer to ScanSnap Home Setup.
1) Click the "Show Hidden Icons" button on the bottom-right corner of your desktop and find the ScanSnap icon. It will be a blue icon with an "S" in the center.
2) Right-click the ScanSnap icon and select "Scan Button Settings".
3) If it is checked, uncheck the "Use Quick Menu" box.
4) Click the "Add or Remove..." button.
5) Click "Add" button
6) Type "Smokeball" into Application Name field. Then click "Browse" button.
7) Navigate to C:\Program Files\Smokeball\binaries and double-click "Smokeball Scan".
8) Click "OK"
9) Click "Close"
10) Check the box next to "Use Quick Menu"
11) Click "Apply"
12) Click "OK". You are now ready to use ScanSnap with Smokeball!
ScanSnap Home Setup
1. When you open up ScanSnap Home, add a new profile under the Scan Settings
2. Complete the set up of the profile
- (1) Select "Auto Scan"
- (2) Rename "Auto Scan" to Smokeball
- (3) Add "Smokeball Scan" to the Application option
3. After scanning a document, anew Smokeball window will open.
- From the new window, select the matter, rename, and save to the matter.
