Quilia partners with Smokeball to automate client communication and case updates in your personal injury matters. The Quilia app boosts client engagement through more efficient case management. For example, you can:
- Sync case progress with your clients and avoid sending manual updates
- Set up automated updates and reminders through the Quilia app to reduce the volume of inquiries you receive from your clients
- Users can track milestones on the Quilia app as their case advances to ensure compliance and better case outcomes
Set up Quilia
- Navigate to quilia.com and create an account.
- Log in to your Quilia account and navigate to the Integrations page.
- Select Smokeball from the list of integrations and select Connect.
- Enter your Smokeball credentials into the pop-up window.Â
- Select Allow Access to connect Quilia to Smokeball.
Once you have set up your account, you should introduce the Quilia app to your clients as soon as possible. Your clients can download the Quilia app from the iOS app store or Google Play.Â
You can learn more about using Quilia at support.quilia.com.
Support
If you need assistance in setting up or using Quilia, reach out to their support team at support.quilia.com or over the phone at 702-337-3127.Â
