There are two different types of If/Then/Else statements that allow you to add advanced automation into your documents.
You can build an If/Then/Else Field Statement or If/Then/Else Ask Statement.
If you have different versions of a fee agreement or pleading, it may be possible to convert them to one document as a result.
The below If/Then/Else Statement is built based of an Ask
How to Build an If/Then/Else Ask Statement
- This example will be built to satisfy the following conditions:
- We want the document to ask, true/false if the client owes fees.
- If the client owes fees, the document should insert language prompting the client to pay the amount owed.
- If no fees are owed, the document should insert language thanking the client for their payment.
- First make sure to create the appropriate Asks required for the document.
- You will need two questions, one for the true/false Ask and another to insert the amount owed.
- Learn more about creating Asks.
- Under If/Then/Else tab of the Automation Toolbar, select the Ask and insert the statement in your template.
- Once inserted, edit your If/Then/Else statement
- If the answer is "true," meaning the client owes fees, insert language under "true" and the ask within the true part of the If/Then/Else statement.
- Insert the Ask like you would normally anywhere else in a document. Learn more about Asks.
- If the answer is "false," meaning the client does not owe fees, insert language under "false."
- When using the statement in a document, the below will happen based on how the Asks are answered.
- To test your If/Then/Else statement while automating, (1) select "run questions for this form" and (2) toggle to "show values"
- You can copy and paste If/Then/Else to appear multiple places in a document
- You can insert (nest) an If/Then/Else Statement (both Field and Ask) within an already existing statement for additional options.
- The below is an example of an If/Then/Else Statement built off of a Choice Ask.
