Import Files and Folders
Grow/Prosper+ Web App
While documents can be created directly in Smokeball, documents and folders created elsewhere can also be saved to your matters.
When you import folders, the current folder structure is maintained.
Smokeball Grow/Prosper+
 At the top of the Matter Screen, click the Import button and select File or Folder
Locate and select the file or folder you want to import and complete the import.
A quick and easy way to import is to drag and drop from a folder or your PC into the Files section in a Matter
If you ever want to get a document copied outside of Smokeball, you can also drag and drop out of the Files section in a Matter.
If necessary, you can delete a file or folder from your matter.
21 out of 36 found this helpful
